C63 AMG (W204) 2008 - 2015
The reason to use adjustable sway bar end links
Old Mar 10, 2012 | 03:46 PM
AMG-010's Avatar
2017 AMG C43
Hi Craig Have you had a chance to ship the longer rods to me as yet. My car desperately needs a wheel alignment and wanted to get these fitted at the same time
Old Apr 2, 2012 | 02:46 PM
AMG-010's Avatar
2017 AMG C43
Sent 2 PM's and haven't heard back off you. When can I expect the new rods to arrive?
Old Apr 2, 2012 | 03:17 PM
dodger63's Avatar
2013 f250 6.7 diesel
When I was there over a week ago, I saw a bunch of them come in. I'm 99% sure he said he shiped yours ill text him and and find out right now, I know his shop has been busy last couple weeks
Old Apr 2, 2012 | 04:51 PM
AMG-010's Avatar
2017 AMG C43
Thanks Dodger. Im really keen to get these fitted asap
Old Apr 4, 2012 | 03:57 PM
AMG-010's Avatar
2017 AMG C43
Dodger did you hear back of Craig as I haven't heard anything as yet
Old Mar 24, 2014 | 01:43 PM
kaunetroxx's Avatar
C63AMG
installed sway bar links from agency power on my c63, started squeaking after few weeks, anyone knows why? how to fix this? or should i go back to the original ones?
Old Aug 14, 2019 | 11:31 PM
  #32
PhillyC63's Avatar
C63 AMG
Originally Posted by Staff@RPM
Most of your vehicles will not need our adjustable sway bar end links but there is a small number of people who definitely can benefit from them. These end links are for those customers that purchased coil-overs and have made the investment to have the car corner balanced. You cannot corner balance your car correctly without these sway bar end links.
The first step in corner balancing your vehicle is disconnecting the front and rear sway bar. In order to corner balance your car, the pre-load from the sway bars has to be released to get a correct reading. After you are done scaling the car it is time to put the sway bars back on. Check your car on the scales after you have attached the sway bar and you will see that all of your weights have changed. With the adjustable sway bar end links you can adjust the bar to the exact weight that was there before you attached the bars. Once you make this adjustment and the weight is the same with and without the sway bars connected you have managed to set your sway bar to zero pre-load which is exactly where you want them to be.
There is also the ability to shift weight around the corners of your car through pre-load. You can now easily move weight from the right side to the left side rear of your car and vice versa. I'm sure your can come up with some ideas on how that can help you at the drag strip and in certain situations.
If you have any questions please feel free to ask. I have learned a lot about this stuff in the last year or so but I am still learning a lot about it. From what I have seen so far, I do not know how they can sell coil-over kits without these parts.
THERE IS NO WAY THIS CAN BE DONE WITHOUT THESE END LINKS!!!!!
Attachment 380442
FRONTS-$325.00/pair
REARS-$275.00/pair
Anyone know if these links are still made/sold for US spec cars? Any feedback from anyone with them if so?
Im not loving the agency power reviews I’ve read including above, so I’m looking for an alternative. Messaged BLKROKT about his kits but no word yet.
Old Aug 15, 2019 | 12:34 AM
  #33
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Sorry, crazy week and behind on messages. Agency Power blows. I have a set of the indestructible overkill links already made and ready to ship. Will respond on PM.
Old Aug 15, 2019 | 04:49 PM
  #34
PhillyC63's Avatar
C63 AMG
No prob dude, dibs on those. Also if you ever got kmac front rear adjustment kits installed, I would like to pick your brain about them if possible? Just let me know. FWIW, Im basically upgrading my entire suspension all in one shot (so im trying) so naturally I have some questions/concerns.
Old Sep 19, 2019 | 04:55 PM
  #35
milehighamg's Avatar
2013 C63
Came across Agency Power as well since mine need to be replaced after adding coilovers. Are they really that horrible? Luckily I came across this thread. Let me know if you have another set blkrokt.
Old Sep 19, 2019 | 05:42 PM
  #36
BLKROKT's Avatar
Done making them, just too much hassle and I don’t have the time. I left insanely detailed instructions on the other thread on how to make them.
Old Oct 30, 2019 | 05:39 PM
  #37
PhillyC63's Avatar
C63 AMG
For what its worth dude I stumbled on these today. This fab co seems to make bit of custom suspension parts for the AMGs and Ive seen some mixed reviews, but maybe worth a shot
https://www.ebay.com/itm/Mercedes-Ad...-/302905744043
Old Aug 1, 2024 | 05:06 PM
  #38
Andreas23c's Avatar
C43 amg
Hey can you WhatsApp message me at 375 96177355 I need some for the front of my c43
Attachment 380442
FRONTS-$325.00/pair
REARS-$275.00/pair
would like to buy front set for my c43 amg if you could message me on email at andreasc5523@gmail.com thanks
