C63 AMG (W204) 2008 - 2015
H&R Springs, to get the 17mm spring pad or no
Old May 22, 2021 | 02:51 PM
benben01's Avatar
2014 C63 507 Sedan
Originally Posted by Mikegpr03
If you use the stock pads the car with have a level drop. The issue is that the fender well is at different hieghts so the car will look like the rear is slammed. Trust me I went thru the HR springs and ended up with coil overs in the end only to finally trouble shoot the odd "clunk " every one gets which by the way is fixed with a $.25 washer. Get the thicker pad 12-17 so the car looks even.
Revising an old thread.. What is this 25 cent washer fix as I am starting to get the clunk sound in the with my KW V3 setup that has about 30K miles on it now. Thx!
