Long Tube Headers group buy?
Specs:
The heat expansion of the exhaust system is a very critical factor on these 6.2 engines, and it often leads to the failure of one or more components, if the design does not take it into the proper consideration. The Supersprint headers, with their proprietary free-floating flanges and spring-loaded sealing rings, effectively neutralize all of the heat induced tensions placed on the individual pipes; provide the ideal resistance of the entire system to the thermal cycles, and a maintenance-free, long life.
The simple, yet effective leak-free design makes the Supersprint headers the only real performance headers on the market, which offers the same oem-comparable, or even better reliability in the long term.
Separated primary pipes 45mm external diameter, 1.5 thickness
4 into 1 manifold, exit pipe 70 mm ext. dia., 1.5 thickness.
It has to be fitted with the front pipes, cat or decat (846602-22 or 846612). We can provide the necessary adaptors or modifications to fit them with the stock centre and rear exhaust, for free.
