C63 AMG (W204) 2008 - 2015
Wherer to buy Mobil 1 Formula M in Canada?
Old 02-25-2012, 07:27 PM
Pit-Pony's Avatar
2015 C63S E1 (sold 2012 C63 AMG Sedan (Premium & APX)) & 09 C300 Sport 4Matic
The MB dealer sells the Formula M 5w-40 for over $10 per liter.
Any other sources in Canada to buy by the case?
I plan to change my oil more much more frequently that the MB recommendation.
Old 02-25-2012, 07:30 PM
Mr. Happy's Avatar
2014 Lotus Evora S
Canadian Tire was carrying it a while ago. I haven't checked lately.
Old 02-25-2012, 07:42 PM
crazy1469's Avatar
2010 C63
i have seen it at canadian tire, walmart, and the odd time at costco
Old 02-25-2012, 08:06 PM
Pit-Pony's Avatar
I checked all these sources and no luck so far.
Old 02-25-2012, 09:18 PM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
My local ESSO station orders it in for me. Its about $6.50 a ltr buying by the case
Old 02-25-2012, 10:22 PM
jarjoug's Avatar
2006 BMW 330i, 2009 C63
Always at Crappy Tire, but I found it once at Costco, bought 48 liters.
George
Old 02-25-2012, 10:57 PM
1st amg's Avatar
SLS Irridium silver,2014 GL350 BT Irridium, 2015 White Dodge RAM Hemi Quad
Parts Source always carries it in Canada
Old 02-26-2012, 12:14 PM
Jasonoff's Avatar
Received 1,594 Likes on 938 Posts
2010 C63 AMG
Thanks for the tip. Sent you a PM.
Old 02-26-2012, 01:42 PM
Green E-300 DT's Avatar
Late Built 2005 W-211 E-320 CDI
Question Are You Sure
Originally Posted by crazy1469
I have seen it at Canadian Tire, Walmart, and the odd time at Costco
Perhaps you saw regular Mobil 1? But not Mobil 1 ESP 'M' Formula!
I'm sure that Costco did not nor would even bother to stock ESP 'M' oil at least in the States.
Walmart does not either! I asked.
They do not stock any oil that meets the VW 507.00 or MBZ 229.51 specs.
As far as Canadian Tire, I doubt that also.
Derrel
Old 02-26-2012, 01:46 PM
gthal's Avatar
2012 C63 coupe
Derrel
+1... I have looked at Canadian Tire and other "retailers" in Canada and have never found oil that would work in my previous car (M3) or the C63. They are too specialized and low volume for them to carry. Too bad, really.
Old 02-26-2012, 02:12 PM
justthebest's Avatar
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
I've actually found most oils pretty cheap online (even with the shipping). Google it!
Old 02-26-2012, 02:33 PM
Pit-Pony's Avatar
I'll check to see if any local Mobil dealer can order it for me.
The Canadian Mobil web site does not list it at all, the US site does.
Oil can not be shipped across the border like any other package either.
Old 02-26-2012, 05:10 PM
Pit-Pony's Avatar
What other brand oil meets the spec?
OK, found it:
http://bevo.mercedes-benz.com/bevolisten/229.5_en.html
Old 02-27-2012, 01:54 PM
Arrow Here's Another Oil
OK, found it:
If you would consider running a 5W-30 weight, you can get Castrol from your VW dealer that has basically the same specs as Mobil 1 ESP 'M' formula.
Many say that the factory recommended Castrol oil is more like 5W-38 weight! It carries the VW specs 507.00.
Many VW people use Mobil 1 ESP formula 'M' oil (5W-40) instead of the factory Castrol oil.
Derrel
Old 02-27-2012, 02:24 PM
Pit-Pony's Avatar
Must be 40 weight for the 156 engine.
Old 02-27-2012, 03:32 PM
1Lop2K5C's Avatar
C63
Keep in mind that the M156 could run both 229.5 and 229.51 spec.
Old 02-27-2012, 03:37 PM
Pit-Pony's Avatar
Check the lists on my link above, same brands show up in both specs.
Old 02-27-2012, 03:44 PM
1Lop2K5C's Avatar
C63
There is a slight differences if you look at the details:
For 229.5 spec there are
Mobil 1 0W-40
Mobil 1 Formula M 5W-40
For 229.51
Mobil 1 ESP Formula M 5W-40
Either way, works for the M156.
Old 02-27-2012, 06:07 PM
Mort's Avatar
I picked up some some Total (Re-branded ELF for NA) Quartz Energy 9000 5W40 to try. No price savings as I paid $12/L in 5 liter jugs. It is specked for MB 229.5.
Old 02-27-2012, 09:39 PM
andrew c230k's Avatar
W204 C63 R171
I just went thru the same thing looking for 0W40 & 5W40 Formula M... personally I wouldn't use formula M in the C63 because its got formulations in it for diesel particulate filter conditioning... its recommended for my 320CDI
If your in Toronto I can point you in the direction of $8.50L
Parts source has 0W40 for $11.99L They do NOT have 5W40 Formula M on the store shelf maybe they can order it in.
Some of the bigger Canadian tire stores have 0W40 also for $11.99L They do NOT have 5W40 Formula M on the store shelf maybe they can order it in.
Walmart sells mobile 1 for 11.27L but they don't have any 40 weight oil in my town.
Local dealer sells for $11.05L
I bought 2 cases of 0W40 today from an oil distributor at about $9.00L
Also if you look at this chart which can be found in your owners manual 0W40 is a bit overkill even for Canada it hardly ever goes down to -30 C
Realistically where I am in Canada I could get away with 10W40 but good luck finding it.
Martini747 (09-26-2016)
Old 02-27-2012, 09:43 PM
Pit-Pony's Avatar
I'd like to stay with 5W-40 as commended by MB.
The dealer sells Mobil 1 Formula M 5W-40 for just under $11/L + tax.
I'd love to find it cheaper if it can be bought by the case for the inter scheduled oil changes I would do myself.
Old 02-28-2012, 01:45 PM
W204 C63 R171
Where are you located ?
Old 02-28-2012, 04:53 PM
Pit-Pony's Avatar
I'm in Nova Scotia.
take a look at this "Oil and 156 Motor" thread in the AMG Private Lounge, General Discussion Section.
Very interesting.
Old 02-28-2012, 10:22 PM
W204 C63 R171
link please
Old 02-29-2012, 05:35 PM
Mort's Avatar
Originally Posted by andrew c230k
link please
You will need to register.
http://www.mercedes-amg.com/privatel...ration/welcome
Quick Reply: Wherer to buy Mobil 1 Formula M in Canada?
