C63 AMG (W204) 2008 - 2015
Aftermarket Wheels and Offsets...
Old Feb 29, 2012 | 02:40 PM
dubaudi's Avatar
2009 C63
OK, so I did some searching but wasn't able to find a conclusive answer to this question. I'm trying to figure out what are the appropriate widths and offsets that most people use for an aftermarket wheel, in 19 inch. Versus stock offsets.
For example, on my old Audi, the stock wheels were 18x8 with 42 offsets. When going up to a 19x8.5 I used 32mm offsets for a good fitment without any "poke".
What would be the right 19 inch widths front/rear and offsets? And what other AMG models is that comparable with? For example, would 19 inch wheels made for an '05 E55 be a good fit on the C63?
Thanks!
Old Mar 1, 2012 | 12:27 AM
Strafe1's Avatar
2021 E63 S Sedan
Most common are:
19x8.5 ET54
19x9.5 or 19x10 ET50
Old Mar 1, 2012 | 09:24 AM
bobbyzcar's Avatar
Originally Posted by Strafe1
Most common are:
19x8.5 ET54
I think you meant to say 19x8.5 ET45 for the front.
8.5 ET54 would be pushed in even more then stock...might even rub the brakes.
Old Mar 1, 2012 | 09:42 AM
crazy1eye's Avatar
2016 C63S, 2012 ML350
I myself have searched Both C63 & C class forums & IMO for a rear 9.5" wheel, +50 would be an ideal offset especially if you plan on running P275/30R19 tires & lowering the car. I just bought a set of 19" Stance SC-5ive wheels & the rear 9.5" has a +48 offset & judging by some pics of member "silversx" car in the C class forums who's running P265's on his SC-5ive's, the P275 is going to be close.
It really depends on 2 things, are you lowering the car & what size rear tire your going to use??
Hopefully I'll have the wheels, tires & H&R springs on in a few weeks, will post pics then.
Old Mar 1, 2012 | 05:35 PM
Strafe1's Avatar
2021 E63 S Sedan
Yes! Thanks for catching that typo!
Old Mar 1, 2012 | 05:47 PM
CampioniShop's Avatar
Former Vendor of MBWorld
Unfortunately Mercedes-Benz designed the C Class with an extremely high offset for the rear, even on the AMG cars! Your selection is limited from other Mercedes models, actually none other than the C Class W204 wheels will fit.
Ideal would is 19x8.5+45 19x10+50.
If you need further help in your wheel selection - let us know!
Thanks!
Old Mar 18, 2012 | 09:50 PM
petmako's Avatar
2011 C63-P31 package
Pm sent
Old Mar 19, 2012 | 09:37 AM
dubaudi's Avatar
2009 C63
Originally Posted by petmako
Pm sent
I didn't get your PM....I'll send you one...
Old May 12, 2012 | 02:50 PM
bluejae's Avatar
'10 C63
are those the numbers recommended for the front and rears?
Old May 12, 2012 | 03:11 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
I will say it again, 19x10 +50mm offset will rub on 275/30 IF u plan on lowering. I don't rub cuz my rears have +52-53mm offset.
Old May 12, 2012 | 03:19 PM
bluejae's Avatar
'10 C63
i won't be lowering my car... my front lip is too low as it is... so i've been thinking about 19s... so i'm just looking around for information. thanks
Old May 12, 2012 | 03:34 PM
Roswell's Avatar
If ur nor lowering bluejae, then u'll be ok with almost any combo. Lol But trust me, once u get wheels, the temptation to lower is big.. Lol
Old May 12, 2012 | 03:39 PM
bluejae's Avatar
'10 C63
i'm sure i'll be tempted... i've already been tempted several times but the front lip is already too low... unless i get a new front lip or perhaps the dtm bumper, i don't see myself risking the height...
today i saw this slammed scion driving through this shopping area (known to have 2-3 huge speed bumps)... he never made it over and ended up turning around while traffic waited for him to reverse, forward left, reverse right, forward left, reverse right, and then drive off...slowly
Old May 12, 2012 | 03:45 PM
Roswell's Avatar
^^ lol at the slammed Scion.. Haha!
H&R is that much lower than stock.. U can see the after & before pics i posted in the FXAutodesign H&R special thread.
