eurocharged in the GTA
2010 C63
is anyone around the toronto area that is eurocharged tuned....
would be nice to have something to compare to....
thanks
thanks
12 MB C63
12 MB C63
I have one thing unsure about it, after you had the tune, will it still be any gas delay when you apply to the paddle? I know for the oem, it does for about 0.8 sec delay..
Mike from Eurocharged will take care of you, my brother had his car tuned by Eurocharged, and mine is a Kleemann tune,
Our cars are neck and neck.. only thing is I paid a bit more for my tune from Kleemann, cause EC Canada wasn't set up at the time..
But I know Mike's customer service is Top Notch
I think he means the delay in response time when throttle/pedal is pressed. There is a slight lag / delay the moment you press gas, before the car actually reacts to it and goes.
From what I read and hear, the tune does help the delay.
There was never a 0.8s delay with the throttle peddle. That would be horrendous!
If you force a gear @ 3-4K rpm there's no throttle delay with the tune. Although I don't remember a delay previous to the tune either.
sure let a girl answer your questions
i believe you're talkign about the drive-by wire delay, if so you will feel a difference
this taken from Sprintbooster:
The ETC (Electronic Throttle Control), which is also known as Drive-By-Wire, has the unfortunate downside of delayed response and subdued acceleration, which can create problems in certain situations such as up-hill starts, quick gearchanges and overtaking.
Should have a meet up with some of the GTA guys soon. I am EC tuned, but on a 55K so different animal. I have Personally seen EC tunes gain 40+ whp on the dyno for 63 series cars.
