C63 AMG (W204) 2008 - 2015
Rubbing noise while turning?
Old Mar 12, 2012 | 06:00 PM
stangxs's Avatar
c63, 11 e350 (DD)
Only happens when I first start the car (when the cars cold), noise goes away after 3-4mins, but it almost sounds like the tires rubbing (but they don't), can it be an issue with the powersteering pump making noises?
I have coil-overs BTW, but I don't think that's the issue
Old Mar 13, 2012 | 01:44 AM
sighting's Avatar
e63s edition 1
what tires you have on? The most unseen places for rubbing is on the back wheels brake lines. you can see it from under the car. I have now seen 2 c63's with severe shaving on the rear brake lines. both of them ran 285's. needles to say, that is a very very very bad place to be rubbing..
Old Mar 13, 2012 | 12:41 PM
Mort's Avatar
Do you park outside and is it damp there a lot now? Check for rust on your rotors. It takes a few minutes for the brakes to clean it off and will make a noise when turning because the rotor will flex just a bit from the centrifugal force of the tire turning and cause the rotor to rub on the brake pad.
Old Mar 13, 2012 | 01:00 PM
stangxs's Avatar
c63, 11 e350 (DD)
I currently have 265's with 10mm spacers so I'm pretty sure the tires aren't rubbing on the brake lines (I had 275s but went down to 265 due to rubbing on the fenders).
The car is parked in my garage all the time, so that can't be the issue.
Probably just take it to the dealers and have them look at it.
Thanks for the input guys!
Old Mar 13, 2012 | 06:32 PM
BerBer63's Avatar
2009 C63
PS pump...check fluid level and release air bubbles with a few lock to lock turns with cap off. happens more so in the cold
Old Mar 13, 2012 | 07:07 PM
stangxs's Avatar
c63, 11 e350 (DD)
Will try! Thanks man!
Old Mar 29, 2012 | 04:43 PM
Benzonator's Avatar
2010 C 300 Sport
Did that solve the problem, stangxs?
Old Mar 29, 2012 | 08:50 PM
stangxs's Avatar
c63, 11 e350 (DD)
Nope, haven't really had time to like into it.
I'm going to check the PS pump this weekend; but I did check the owners manual, couldn't find where the PS pump was, and where the fluid goes?
Old Mar 29, 2012 | 09:31 PM
skokkosis's Avatar
2014 E63-S, 1987 190E 2.3-16, 1985 325E
i've had the same damn problem for a while now, my car is about a year and a half old, it started on mine about 3-4 months in since the purchase, i took it to merc. twice, one time they found some leak in the power steering, replaced the fluids and part, and told me it'd be fine, still was there... like yourself when the car is cold only the first few minutes of the drive, then i went in for service a while ago, told them it's still going on, and they told me that it's the tires... because i run blizzaks on the wheels in the winter... i assured them that the noise was there before hand and was not fixed when i reported it first a while ago, they said they checked everything and could not find anything wrong... still a damn mystery to me
and... they said they heard it when i went for service, and the tech said it's the tire's thick treads on the ground.. please... lazy bums... hasn't showed any problems, and they can't see any damage, so it can't be anything too serious, just damn annoying
Old Mar 29, 2012 | 09:49 PM
BerBer63's Avatar
2009 C63
it's under the V portion of the engine cover. Cap has a dipstick with temperature specific PS fluid levels on it. Best to keep it close to the top of the fill line given the engine temperature (cold or operating temp)
Old Mar 30, 2012 | 01:01 AM
tampabayboy's Avatar
2012 C63 AMG Coupe
Does it happen while you are driving straight or while making turns? Do you have a rear differential?
I had an issue with my M3 where I would get a rubbing sound while making turns in my parking garage. It sounded like my tires were rubbing in the turn, however, it ended up being the rear differential. Just needed to replace the differential oil and it cleared it up the noise.
Old Mar 30, 2012 | 01:26 AM
C63 Guy's Avatar
none
I dunno about turning, but I make a rubbing noise pretty much any time I look at or think about my car...
Josh
Old Mar 30, 2012 | 01:32 AM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
Hmm, I'll have to check that out when I go for my oil change on Monday. Is there a way like other fluids to tell if it's getting old or grimy?
Old Mar 30, 2012 | 01:52 AM
skokkosis's Avatar
thanks tampa, i will follow up on what you said, because it is during turning only and when it first turns on, may be a similar situation as you had on your M, and they've been checking the front wheel sections and steering since those turn, they probably haven't taken a look into the rear, thanks for the help
Old Mar 30, 2012 | 06:02 AM
drjazzsk's Avatar
2009 C63
had a similar issue at startup, while backing up and turning to either side. Made a scrapping/catching type noise as if the tires were rubbing. It wasnt the tires. Took it in and MBZ said it was a bushing issue that there was a TSB out on it. replaced under warranty and seems resolved.
Old Mar 30, 2012 | 12:28 PM
stangxs's Avatar
c63, 11 e350 (DD)
Awesome; thanks for all the info, guys!
Old Mar 30, 2012 | 01:30 PM
BerBer63's Avatar
2009 C63
What's the TSB, they put it on your paperwork?
