C63 AMG (W204) 2008 - 2015
Coolant usage-may be the "bad news"
Old May 14, 2012 | 03:12 PM
  #151
j bro's Avatar
2009 C63 ///Amg
09 at 40000 miles and i just made a 2000 mile drive and the coolant level msg showed up, went in for a b service and the topped it up , should i be going back to get it checked out?
Old May 14, 2012 | 03:19 PM
  #152
b16's Avatar
b16
2009 C63, 2000 ML 430, 1994 Del Sol Vtec
I would..
Old May 14, 2012 | 03:54 PM
  #153
DuaneC63's Avatar
AMG GLC63. Audi R8
Absolutely. If it is a head gasket leak it's only going to get worse. Get a narrow metal ruler marked in mm and use it as a dipstick to check the coolant in the reservoir every morning with the engine dead cold. The problem with waiting for it to get worse is you risk hydro-lock which can cause serious damage. Other indicators are high oil level indicator and white sweet smelling smoke on start up out the exhaust. If the problem becomes persist, do not drive to the dealer, have it flat bedded in.
Old May 14, 2012 | 05:38 PM
  #154
carjones's Avatar
2009 C63
In my case the failure occured almost overnight. The vehicle just started using coolant (a lot)but showed no other symptoms.
Carjones
Old May 14, 2012 | 09:39 PM
  #155
JohnnyUte's Avatar
C350 4matic coupe
Another warning sign is white "smoke" coming out of the exhaust on days that aren't cold. I used to own a car that had Ford's 3.8l which was notorious for blowing head gaskets.
Old May 15, 2012 | 09:41 PM
  #156
morganb's Avatar
C63 AMG, C36 AMG, SL500
Update on C63 in Garage
Originally Posted by morganb
Update on my Car. MB says it not the head bolts. Requiring a full engine strip down to determine whats wrong. No help yet from MB Aus on the cost of this though it seems like some sort of catastrophic failure which I do not think should have occurred on a 3.5 year old 51K KM motor serviced on the dot by MB themselves. The Service Tech says he has not seen a similar type of failure! Will know more on Monday.
Spoke to the Service tech last night. Apparently the "good" side with compression has had one head bolt fail. I guess this was a ticking time bomb anyway. Thanks for the new head bolt number, as this goes back together I will make sure the new ones go in.
BTW I thought he intially told me issues with 1,3 and 8 cylinders so I must have got this wrong. Strip down is continuing slowly. Each step is being communicated to MB Aust and waiting their feedback.
Old May 15, 2012 | 09:55 PM
  #157
Watchbeat's Avatar
2011 AMG SLS, K&N Air Filter, Cargraphic Exhaust, Klassen M51R Wheels
This sounds pretty scary!
Although I have just purchased a new old stock (1/2011 Built with engine # ending 600 663 XX) from the AD and done only 900km, I just hate to hear this happen!
Hope MB already changed and used new bolts on mine!
Old Jun 6, 2012 | 09:55 PM
  #158
morganb's Avatar
Update on Morganb's car
The heads have been off and X-rayed looking for porosity, nothing found and they were all perfectly flat.
The Block is now going for the same treatment. Hopefully will know something on Friday or Monday.
To summarize: 2 cylinders no compression due to valves not sealing, one broken head bolt (not bad leak), and water in 3 cylinders not related to the head bolt. As yet it seems no reason found yet as to what would have caused all this. The scary thing is until 2 minutes earlier the car was running great with no warning lights. Then low water warnings and about 30 seconds running time later the CEL came on and the car was running rough and putting out a smoke screen the Batmobile would have been proud of.
Bruce
Old Jun 6, 2012 | 10:19 PM
  #159
Sincity's Avatar
Thanks for the update.
Old Jun 6, 2012 | 10:42 PM
  #160
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
And the saga continues. Continue to keep us in the loop please!
Old Jun 6, 2012 | 10:47 PM
  #161
SonnyakaPig's Avatar
MB
Old Jun 7, 2012 | 12:32 AM
  #162
bhamg's Avatar
C63 AMG
Interesting...hope the good-will issue works out for you.
Old Jun 13, 2012 | 10:07 PM
  #163
morganb's Avatar
Morganb's on going saga
Well they cannot find anything wrong! The water on one side in the cylinders seems seems to have magically appeared there! They are sending out the head assembly with a new set of head gaskets to be bolted to the block (still out of the car) and then pressurizing the cooling water ways to look for leaks! I have never heard of this before with a motor out. Any comments from technical experts would be most welcome.
Now 5 weeks and still do not have a cause. This is becoming very frustrating.
Old Jun 14, 2012 | 12:00 AM
  #164
DuaneC63's Avatar
AMG GLC63. Audi R8
There is no magic involved. Either is comming from a blown head gasket (the normal problem) or you have a porous engine/head casting which is very unlikely but could happen. Although this must be very frustrating, MBZ is working on the problem and will eventually fix it (perhaps with even a new motor). As long as they gave you a loaner to drive, i'd rather have them take the time to get it right. Best of luck.
Old Jun 14, 2012 | 12:11 AM
  #165
morganb's Avatar
No loan car! When the head first came off I was told one side had one head bolt fail but water was in both banks of cylinders. Its leaning towards a crack or porosity but it seems difficult to find.
Old Jun 14, 2012 | 12:17 AM
  #166
DuaneC63's Avatar
AMG GLC63. Audi R8
No loaner car is total BS. Your dealer sucks not offering you a loaner. Head bolt failure on the M156 is known by MBZ and a known failure. Block porosity is less common but not unheard of. In either case you should have been given a loaner until they figure out the problem.
Old Jun 14, 2012 | 01:07 AM
  #167
MB
The problem is a consumer has less power than the manufacturer and even a dealership until the consumer files a lawsuit and commences discovery. But, that costs time and money so there needs to be some good evidence that (1.) there is a problem and (2.) MB knows about it before a lawyer will get involved and take the case on contingency. Otherwise it's up to the consumer to pay to protect their rights. If the consumer's loss is limited to out-of-pocket rental expense, the best forum to recover that amount would be small claims court. Tough situation but unfortunately very common.
Old Jun 14, 2012 | 01:08 AM
  #168
DuaneC63's Avatar
AMG GLC63. Audi R8
There is a class action suit regarding this issue.. Google it.
Old Jun 14, 2012 | 01:13 AM
  #169
MB
I will, thank you. But, the commencement of a class action suit (depending on the stage of litigation) does not necessarily get @morganb and other like consumers in a rental car if the dealer is unwilling to provide one.
Old Jun 14, 2012 | 01:17 AM
  #170
MB
That's old news about the class action and that class action isn't related to this head bolt issue. Further, there have been no updates relating to that class action about the metallurgy problem. That issue is now quiet.
Old Jun 14, 2012 | 01:19 AM
  #171
morganb's Avatar
Thanks for the advice. I am in Australia so not sure how any US class action would affect me. I am lucky I have a few cars so I have been driving some of the others over the past 5 weeks or so. I have not had to rent a car.
Old Jun 14, 2012 | 01:26 AM
  #172
DuaneC63's Avatar
AMG GLC63. Audi R8
Unfortunately you are correct. Loaner cars are goodwill by the dealer. It is very sad MBZUSA is acting like most american car manufacturers regarding known defects. Of course some MBZ dealers are much more accomodating than others regarding loaner cars. My wife has a Lexus and they break their backs to make you happy. But don't feel to bad..when I take my MBZ in, I get an MBZ loaner. When my wife takes her Lexus in she gets a Lexus loaner. When I take my Porsche in I get a Mazda (nothing against Mazda's).
Old Jun 14, 2012 | 01:30 AM
  #173
MB
Unfortunately you are correct. Loaner cars are goodwill by the dealer. It is very sad MBZUSA is acting like most american car manufacturers regarding know defects. Of course some MBZ dealers are much more accomodating than others. My wife has a Lexus and they break their backs to make you happy.
My local dealer used to offer loaner cars as standard practice, now it's at their discretion and they don't offer this courtesy very often. Too bad.
Old Jun 14, 2012 | 02:09 AM
  #174
bhamg's Avatar
C63 AMG
While we were working through a major engine issue in the M5 my dealer provided me with a loaner. One month became two, eventually stretching out to five months. I was in town for four of those five. I got an X5, assorted 5 series and a 3 series wagon (my favorite). Once I called the BMW store in the morning from the airport and told them I was coming in and asked for the demo wagon. They said they had sold it but just to cab in and they would have a car. I got there late afternoon and there was a wagon waiting for me...fresh out of the prep shop and showing all of seven miles on the odo. It doesn't get any better than that.
Old Jun 14, 2012 | 02:13 AM
  #175
MB
That's a really cool experience. Personally, I think dealers are more likely to provide loaners to people that purchased cars from them. This isn't a rule, but I've seen this outcome at my local dealer.
