C63 AMG (W204) 2008 - 2015
Coolant usage-may be the "bad news"
Old 04-14-2012, 01:07 AM
carjones's Avatar
2009 C63
background: got my c63 back from service about three weeks ago. I was driving home three days ago, "check coolant level" comes on.
I think 'probably normal consumption."
get home, allow to cool, add about half a liter, looks good.
Next day, driving to work, no drama, then same message.
I think, I must have not quite added enough.
Allow to cool, now it takes 2 liters.
I think, can't be leaking, as none in the garage and none in exhaust smell.
Next day- same thing
At dealer- at first they said they would test the system.
Today they called, need to keep the car for a few days.
May need to pull heads.
2009 44k miles.
I pretty much baby this thing, only issues was having the intake leak repaired that many of you have had about 6k miles ago.
I'll let everyone know how it plays out. Dealer has always treated me well and been very upfront.
Old 04-14-2012, 01:12 AM
bhamg's Avatar
C63 AMG
Sorry to hear that...looking more and more like a MY 2009 issue.
Old 04-14-2012, 02:01 AM
Merc63's Avatar
C63 AMG
This really worries me as its been only occurring on cars with high mileage and seems to hit once warranty is up.
Old 04-14-2012, 02:52 AM
DuaneC63's Avatar
AMG GLC63. Audi R8
The ECU is programmed to have the head gaskets fail right after your warranty expires.
Old 04-14-2012, 03:18 AM
Faris63's Avatar
'13 CLS63 PP
That's true
Old 04-15-2012, 02:05 AM
carjones's Avatar
2009 C63
I was careful to document all service after reading other members encounters. I just had the "B" service completed and made sure I was following the required maintenance.
Old 04-15-2012, 12:52 PM
Sincity's Avatar
It IS the bad news. This is un-nerving (sp?). Another person with a coolant issue. Based on the number of active members here on this forum and the # of potential failures, the failure rate is unacceptable.
Does anyone have an email address of a contact person? My '09 has 5640 mi and warranty will be up in June '13. At the rate I'm going, my failures may come after warranty which may lead me on not keeping the car though my original plan was to keep for a long time. I could always spring for an extended warranty, but will need to read the policy language on a lightly modded car. Anyone have an idea on costs to replace headgasket and bolts as a preventative measure?
EDIT-correct current mileage to 5600.
Old 04-15-2012, 10:20 PM
bhamg's Avatar
C63 AMG
Sin - Did you add an extra "0" to your mileage?
Old 04-18-2012, 03:59 PM
carjones's Avatar
2009 C63
Update-
Heads are coming off, new gaskets, and lifters.
Old 04-18-2012, 04:21 PM
b16
b16's Avatar
2009 C63, 2000 ML 430, 1994 Del Sol Vtec
Took my car in for a service yesterday and the SA mentioned there is a service bulliten for this. She said if I get the coolant light to turn the car off immediately and have it towed to the dealer.
Old 04-18-2012, 04:56 PM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
+1 LOL I thought when we last checked with him he had like 4000 miles on a car 2 years old...
Old 04-18-2012, 05:00 PM
DuaneC63's Avatar
AMG GLC63. Audi R8
Does anyone have an email address of a contact person? My '09 has 56400 mi and warranty will be up in June '13. At the rate I'm going, my failures may come after warranty which may lead me on not keeping the car though my original plan was to keep for a long time. I could always spring for an extended warranty, but will need to read the policy language on a lightly modded car. Anyone have an idea on costs to replace headgasket and bolts as a preventative measure?
I not sure what the consumer laws are in NV. In Cali if you bought the car new from the dealer you can buy the factory extended warranty at any time prior to the expiration of the primary warranty.
Old 04-18-2012, 05:04 PM
DuaneC63's Avatar
AMG GLC63. Audi R8
2009 44k miles.
These must be failing for a reason. Head gaskets aren't exactly a high tech part. Perhap having the head bolts retorqued every 25K might help avoid the problem. It's hard to believe that an AMG motor would be designed with insufficient size, strength or number of head bolts. If they do pull the heads make sure they are not warped and the deck of the block is perfectly flat.
Old 04-18-2012, 05:06 PM
PaulWdz's Avatar
CLK63 Black Series
2009 44k miles.
That might be the problem.
Old 04-19-2012, 01:14 AM
Merc63's Avatar
C63 AMG
M156 use Torque To Yield head bolts. They are stretched to a specific limit, but if they are over stretched slightly they lose a lot of their strength which can cause these failures we are seeing now.
I am not sure if its the heat, the metal or if they are being torqued too much which is causing the over stretching and weakening. But clearly something is not right.
Here is a good article explaining critical fasteners.
So re-torquing the bolts is definitely not an option. I believe you should only use a Torque to Yield bolt once. I know there is some on the bottom of the tranny pan and I had to use new ones when we did that job.
http://www.enginebuildermag.com/Arti...uetoangle.aspx
Old 04-19-2012, 09:20 AM
black-clk500's Avatar
'14 911S (garage queen) '13 X3 (family hauler)
WTF, good to know.
Anyone know if this is 09 specific or early models specific?
Can't recall seeing any 10's or '11s with this problem, YET.
Old 04-19-2012, 04:57 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
09 here and has over 25k with no coolant usage.
Old 04-19-2012, 05:00 PM
bhamg's Avatar
C63 AMG
We need a catch-all thread across all forums where the 6.3 is used. We've had maybe five threads in two months here with the OP's experiencing head bolt failures and they all will drift down into oblivion eventually and probably be difficult to find with the crappy search function. Let's track this issue (better)!
Old 04-19-2012, 07:28 PM
Former Vendor of MBWorld
Weistec's Avatar
Weistec
Hello Gentlemen we have briefly wrote about this in a similar post regarding these issues. We have an ARP Head Stud available for the M156 and M159 that is far superior to the factory torque to yield bolts, is reusable (if ever you need to remove the head again), and is very easy to install. We highly recommend these for anyone that is removing the heads, either for repair or modifications. PM or email us for more information. Thanks guys.
Weistec Engineering
Old 04-19-2012, 07:33 PM
Even Money's Avatar
'15 VW GTI
Weistec Engineering
Good to know, could you pm, start a thread or post here what parts you have for the M156 that replace OEM parts. Thanks.
Old 04-19-2012, 10:27 PM
BerBer63's Avatar
2009 C63
price, expected time for install?
Old 04-19-2012, 10:30 PM
Sincity's Avatar
You're right. Current 5600 mi.
Sincity's Avatar
+1. Sticky it!
Old 04-20-2012, 05:30 AM
bhamg's Avatar
C63 AMG
At this rate based on my calculations you have 23 years before probable head bolt failure.
Old 04-20-2012, 10:02 AM
carjones's Avatar
2009 C63
Another update-
They are reporting one head bolt had failed and another had area showing corrosion.
I certainly would reccomend watching this on the '09 MY vehicles. In my case there was no early signs, just an immediate change to what had been a normal ownership experience.
I would never recommend reusing head bolts on any rebuild, but especially if you are going into one of these motors for modifications, I would definately replace all of the headbolts with a superior fastener. Most who do this type of work already know this.
If there is someone that has information regarding the TSB on this, we might know the range of affected vehicles.
Quick Reply: Coolant usage-may be the "bad news"
