M156 head bolt problems
so you lost no coolant but 'smelled' some during a routine oil change and decided to pull the head?
no other symptoms
how someone can discern minute quantities of coolant during an oil change
or 'feel it' when mixed with oil
in such small qtys that the coolant level did not change
and why the pan would be pulled to begin with?
and why it would settle in the bottom?
and how you could tell it 'started' since it was only discovered during the oil change
and this resulted in the heads being pulled
without a compression or leak down test
or a cooling system pressure test
etc.
apparently many things
etc.
Amazing isn't it? Maybe Jesus intervened
So by the sounds of it, would Blackstone labs let us know 100% if we would be experiencing a hold bolt failure soon just by the oil analysis? If so, I would absolutely do that every 6 months or so as it would be cheap insurance & maybe we can get a subscription "Group Buy" thing going on
At that point you likely won't be able to remove the bolt even if the head hasn't already snapped of.
etc.
After sitting for a period, the oil and water would separate, how you would feel it, no idea
Make sure all non oil fluids are evacuated? simple oil change might leave non oil fluids in the pan.
Physics... oil and water do not mix, or at least do not remain mixed. Eventually the oil and fluid will separate and the oil will float to the top leaving coolant at the bottom.. Come on, based on some of your engineering type posts, one would expect you to know this.
Another no idea..
By product of combustion
Condensation
Good idea to get it hot and cook it off
Blackstone reports all show some water and fuel but seldom coolant present
Wifes DD, 29K miles. Oil change interval 1 year . 0W-40 Mobil 1. Oil change mileage 4k. Car run in auto only, seldom used hard . No track/drags.
OK-So with that assurance I expect a broken headbolt any time now.
Post script. Iron was the only item discussed in the Blackstone narrative with the report. While it was within the average for "this type Mercedes engine," the level seen was that of the "6700 mile" change interval. Not to worry says Blackstone, but it reminded me of the cam/lifter story.
Last edited by motoman; Apr 1, 2014 at 10:38 AM. Reason: Iron, clarify car mileage
Wifes DD, 29K. Oil change interval 1 year . 0W-40 Mobil 1. Oil change mileage 4k. Car run in auto only, seldom used hard . No track/drags.
FS: 2009 Mercedes C63 AMG | Arctic White/Sahara Beige | OE Tune | Headbolts Replaced
After a few weeks I have new headbolts (mercedes redesign), new tappets and buckets as a precaution. New power steering pump and a few other things it needed. $10k later I am on the road with a bullet proof like new SL63 AMG
To my surpise he called a couple of days later and said they were going to do the upgrade under the warranty!
There is much less engine noise in the engine compartment and is running great!
I believe with all the recall hype in the news today MB doesn't want any bad press so it may be a good time to put some pressure on you dealership to get it approved by MB. Hope this helps ---
______________
