C63 AMG (W204) 2008 - 2015
M156 head bolt problems
Rating: Thread Rating: 3 votes, 5.00 average.
Old Oct 2, 2014 | 05:45 PM
  #801
Ingenieur's Avatar
C63 AMG
Originally Posted by Sincity
Failure in the UK on a 2008 with only 20k miles: http://www.mbclub.co.uk/forums/amg-l...2-%40-msl.html
Previously posted
None were broken
They found 2 loose bolts
I wonder if they stretched?
Most failures have been snapping at the head/shank
Old Oct 2, 2014 | 07:09 PM
  #802
Ingenieur's Avatar
C63 AMG
Does anyone know?
Internal torx tool size, eg, Txx
Shank diameter
For the old style bolt
I thi k I found the oem and want to look at the specs
tia
Old Oct 2, 2014 | 09:01 PM
  #803
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I believe motoman (sp) posted all the specific details re: old vs new bolt specs in one of the threads. Good luck finding it though
Old Oct 2, 2014 | 09:26 PM
  #804
Ingenieur's Avatar
C63 AMG
Been through it once this week documenting the failures lol
Once is enough
Old Oct 10, 2014 | 03:01 PM
  #805
Rock's Avatar
Administrator
Drives Slowly
M156 head bolt data poll started below. Please post if affected.
https://mbworld.org/forums/c63-amg-w...data-poll.html
Old Nov 29, 2014 | 09:26 PM
  #806
Sincity's Avatar
Head gasket replacement video (time lapse):
http://www.youtube.com/watch?v=fYTGj...PigLv_nHwzbfBA
Old Nov 30, 2014 | 09:16 AM
  #807
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Not bad, only took 5min
Old Dec 6, 2014 | 01:34 PM
  #808
glennhl's Avatar
2011 C63
OK, I changed my oil today and I now notice a ticking noise in the valve train. I'll give it a while to see if it goes away. I have a 2011 that does not have the bad head bolts. So my question is, when Mercedes went to the new head bolts, did they also go to the better SLS valve train parts (buckets)?
Thanks,
Glenn
Old Dec 6, 2014 | 06:18 PM
  #809
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Thanks,
Glenn
Yes.
Old Dec 7, 2014 | 08:52 AM
  #810
BlueClk63's Avatar
2019 C63s, 2021 E63s Estate
Just chiming in here...
I have a 2007 CLK63, bought new -- it now has ~149K miles on it (yes, I drive it). @50K, I was one of the first in the country to experience the lifter failure as it took out three of my camshafts. MB was kind enough to pay for that.
@149K, now, I believe I've won the lottery, as all signs are pointing to head bolt failure on my vehicle. At this point I'm hoping the damage isn't too extensive, currently awaiting a tear down. If it's just the bolts, I'm replacing with studs.
Cheers,
Chris
Old Dec 8, 2014 | 11:20 AM
  #811
Merc63's Avatar
C63 AMG
If you catch it early and have a good shop that will switch from bolts to studs one at a time, price shouldn't be too much. They should be able to do the job in 8hours.
If a bolt broke or stretched and the gasket is compromised that could bes larger job. Heads need to come off.
Old Dec 8, 2014 | 05:53 PM
  #812
bhamg's Avatar
C63 AMG
BlueClk63 - If you proceed with a repair, PM me. I might have some useful info that pertains to your FL location. GL...
Old Dec 12, 2014 | 07:50 PM
  #813
Jgrass89's Avatar
07 mustang
Can I please have this 2010 vin number checked?
WDDGF7HB3AF521424
Old Dec 12, 2014 | 09:32 PM
  #814
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
2010 = affected, 2011 = maybe...
Old Dec 13, 2014 | 08:36 PM
  #815
Valvestud's Avatar
WDDGF7HB3AF521424
Again all 2010 and older, and some early 2011s are affected.
Regards,
Joe
Old Jan 11, 2015 | 04:24 PM
  #816
solekeeper's Avatar
A V8
Regards,
Joe
good thing i'm getting a 12'
Old Jan 13, 2015 | 09:21 AM
  #817
MingenPowa's Avatar
C63
hello, pls check
WDDGF7HB2BF600584
and datacard.
Thanks!
Old Jan 13, 2015 | 01:11 PM
  #818
Valvestud's Avatar
Originally Posted by MingenPowa
hello, pls check
WDDGF7HB2BF600584
and datacard.
Thanks!
Datacard attached. This car is not affected.
Regards,
Joe
File Type: pdf
Old Jan 13, 2015 | 03:34 PM
  #819
norb's Avatar
2009 C63 AMG
I already know I"m in the effected range, but might as well check.
WDDGF77X79F278077
Old Jan 13, 2015 | 03:45 PM
  #820
Valvestud's Avatar
WDDGF77X79F278077
No reason to check.
Regards,
Joe
Old Jan 15, 2015 | 08:32 PM
  #821
solekeeper's Avatar
A V8
WDDGF7HB5BF632297
i'm having trouble finding a 12.. this white 11 is appealing to me... i'm so anxious
Old Jan 15, 2015 | 10:21 PM
  #822
Valvestud's Avatar
Originally Posted by solekeeper
WDDGF7HB5BF632297
This one is not affected.
Regards,
Joe
Old Jan 15, 2015 | 11:28 PM
  #823
solekeeper's Avatar
A V8
thanks joe
Old Jan 19, 2015 | 08:48 AM
  #824
solekeeper's Avatar
A V8
WDDGF7HB6BF554595 please
Old Jan 19, 2015 | 10:28 AM
  #825
Valvestud's Avatar
This one is also not affected.
Regards,
Joe
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
