M156 head bolt problems
#1026
Probably even more-so the CLK63 because that was the first to have the M156 motor.
You probably don't hear about it because there's not enough of them around?
#1027
2009 C63
on another note, how much more does this cost to fix preemptively vs after the fact? 2x more? 5x? 10x? seeing different numbers being thrown around. i'm currently at 126k and thinking if it's worth it for me to get my headbolts done. think i should just see what happens? i'm already in the upper miles and not sure how many miles/years i have left even if my headbolts are made of adamantium.
#1028
2007 CLS63 AMG 030; 1970 Ford Mustang Coupe
"Coolant Top Off"
I just got the "Coolant Top Off" warning on the dash for the first time.
Is this one of the warnings?
Folks say, "Low Coolant" is a warning but not sure if that's the same as "Coolant Top Off".
In any event, I'm taking it in.
#1032
Originally Posted by drmike5000
Not a head bolt problem, coolant was leaking onto the ground, cracked thermostat housing
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
#1033
Whether differs on composition of material, head bolts (original OEM) m156 and ARP hairpins?
And what is told by practice, after application of bolts (ARP hairpin)
#1034
My car mileage 29,800 km, and I have no problems ! But I think now to replace head bolts (ARP of a hairpin) and lifters from (SLS black series).... I hope for the future I will get rid of undesirable breakages!
#1035
Does anyone have a parts list for completing this job? So far I have:
http://weistec.com/all/c/c-63/2008-2...tuds-m156.html
http://weistec.com/all/c/c-63/2008-2...e-buckets.html
Left and right cylinder head gasket
4x N 000000 005754 bolts
Two oil filters and oil for two changes.
What else am I missing?
#1036
#1038
Honestly, you probably don't need it if you didn't have a low coolant situation. It's listed in tsb for the dealership to perform the repair if CEL and low coolant light are presently activated.
I guess because MB doesn't perform preventative repairs they are assuming that the repair is being done to a vehicle that actually has a broken head bolt(s)/gasket, at which point, you would probably need the two or three oil changes to make it perfect again.
#1039
C63 AMG, P30
Kamal63 (09-10-2016)
#1041
[QUOTE=AMG3.2;6912381]Take a look here: https://mbworld.org/forums/c63-amg-w...adventure.html
Nice thread AMG3.2!!! That helps a bunch.
#1043
I have just a lifter fail at 198,000km, so while replacing one of the cams and all the lifters I got my indie to pull the heads and replace the bolts while the engine was open.
Had a look at the old bolts and all appeared ok. Real lottery as to whether people will see problems.
#1044
#1045
Change everything
#1046
Originally Posted by Sandpit
I
Did you still have the Mercedes blue antifreeze at this point ?
#1048
#1049
The old style head bolts are a lottery, except there are only losers. The labor to pull the heads is a pretty expense proprosition, so you might as well replace everything. Both cams, all the lifters, have a valve job done (esp at 198k). There are also chain/cam tensioners that should be replaced. All the bolts need to be replaced anyway as they are torque to yield. This includes the manifold bolts.
Amazed how quiet the engine is now
#1050
2011 E63
Hello! this may sound like a silly question, but I have a 2011 E63 which was confirmed to NOT have a headbolt issue (car was produced 10/11 and engine # checked by Valvestud). I was wondering if the car has the new bolts from MB, does that mean is has SLS buckets from factory as well, or not? Thanks!
