C63 AMG (W204) 2008 - 2015
First time out drag racing in the C63!
Old May 4, 2012 | 10:57 PM
EkS's Avatar
EkS
C63
Well I finally got to take out the C63 drag racing. The 1/8 mile track opened up after its bankruptcy fiasco, now gotta wait till the 1/4 mile track finishes with its court hearings to go there.
I was able to get 3 runs in. But I was getting that dreaded 2nd gear "slip" (for lack of a better word) in the 1st and 2nd run. So after the 2nd run I decided to reset the adaptives, and it felt much better and got a faster time. I didn't get a 4th run in to see if it "slipped" again.
What do you guys see that can be done different? What do you guys think my time/mph in the 1/4 mile will be?
Old May 4, 2012 | 11:46 PM
xtyper's Avatar
2013 E63 AMG
1/4 mile those times probably equate to 11.8-12.1 at around 117-119mph.
Nice runs.
Old May 4, 2012 | 11:51 PM
Even Money's Avatar
'15 VW GTI
No way man...well into 11s, if not 11.6-11.7, just compare to some of the other timeslips on the 1/4 mile sticky.
Nice! What was the DA? Once you get the launch down, you can really help your time...
Old May 5, 2012 | 12:56 AM
dodger63's Avatar
2013 f250 6.7 diesel
What mods
Old May 5, 2012 | 10:28 AM
EkS's Avatar
EkS
C63
According to dragtimes DA was between 640 - 750
Originally Posted by dodger63
What mods
MHP 91 Oct tune
MHP Headers
Charcoal Delete with BMC filters
Old May 5, 2012 | 12:20 PM
Merc63's Avatar
C63 AMG
What tires were you running?
I was at the track last night too.
Old May 5, 2012 | 12:30 PM
dodger63's Avatar
[QUOTE=EkS;5181076]According to dragtimes DA was between 640 - 750
MHP 91 Oct tune
MHP Headers
Charcoal Delete with BMC filters[/QUOTE
Cool
Old May 5, 2012 | 02:18 PM
EkS's Avatar
EkS
C63
Running 17" Hoosier DR.
Were you there when I was running? I left early like at 6:30pm. I was still able to get 3 runs in before leaving.
Old May 5, 2012 | 06:22 PM
Even Money's Avatar
'15 VW GTI
I noticed over an hour until your car ran the final time, and best. These cars require a good 6 to 8 runs, basically hot lapping, to do their best. Experiment with your tire pressures too, I think something around 18 psi should do the trick. The launch takes some practice too, it can be finicky. I think maybe launching at just above idle would be best. I tried everything and seemingly trying to launch at 12-1500 rpm, the car seemed to bog or slip as you described. You should easily be able to drop a tenth off that 60, and the car has 11.3-11.5 in it.
Old May 5, 2012 | 09:16 PM
EkS's Avatar
EkS
C63
Actually for the final run I did have the tire pressure at 18 PSI. I started at 25 PSI and worked my way down from there, and ended up with 18 PSI on the last run. As for the launch I was right around 1500 rpm. I never did vary that in any of the 3 runs. I'll try just above idle next time around.
Next up is the 1/4 mile, but I guess I'll have to wait and see when the track opens back up.
Old May 5, 2012 | 09:22 PM
Even Money's Avatar
'15 VW GTI
Cool. Maybe you can run merc, seems if you compare your 1/8 to his, you should easy be around 11.7. Yeah, I think just enough above idle, maybe 800 rpm, to take the slack out. Then maybe try from idle.
Old May 6, 2012 | 12:52 AM
Merc63's Avatar
C63 AMG
Sorry, I was at the track, but my local track in Canada
2800 ft DA... ****tttt
Slow track
Old May 6, 2012 | 01:06 PM
EkS's Avatar
EkS
C63
Slow track
Haha yeah, I noticed that you had 1/4 mile track slip so I was kind of scratching my head on that one.
