C63 AMG (W204) 2008 - 2015
C63 BS Coupé service bulletin
Old May 15, 2012 | 11:19 AM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
Just got a Text from my shop foreman. New Torque spec's on our wheel bolts.
132ft/lbs
Seems high to me but he double checked. Get out the torque wrenches>>
Old May 15, 2012 | 11:43 AM
LangeOne's Avatar
C32, 911 Carrera S(991), C63BS
My car is in the shop for the 1,850 mi differential oil change. Should I ask them to check the wheel bolts?
Old May 15, 2012 | 12:18 PM
PatSC23's Avatar
2009 C63
Damn that is high in comparison - im torquing my C63 to 96.
Old May 15, 2012 | 12:24 PM
Agent_Oorange's Avatar
Cars
Good thing you posted this, had to deal with a flat yesterday, time to get the torque wrench out.
Old May 16, 2012 | 11:30 AM
Faraz's Avatar
C63 Black Series, Magno Alanite Grey
Gents,
Just an FYI, that is not ft/lb --- it's 132/nm, if you have torqued it to ft/lbs, you may really want to revert. 96ft/lb is correct.
-Faraz
Old May 16, 2012 | 11:46 AM
Faraz's Avatar
132ft/lbs
Incorrect bud, hope you didn't torque that tightly!
It's nm's no service bulletin.
Old May 16, 2012 | 12:22 PM
rage2's Avatar
C63 BS, GLA45
Look in your manual, page 257. The torque specs for the spare is 133 lb-ft (180 Nm). There's no mention of the factory wheels. I believe that's what the service bulletin is addressing.
Old May 16, 2012 | 12:39 PM
Wrongo Faraz>>> torqued to 133 ft/lbs (180 Nm)
Old May 16, 2012 | 12:42 PM
Faraz's Avatar
Crazy!
I was just at the dealership for this and he looked it up and said it was Nm....
Can you get me the info on this in greater detail ? Where the tech found it etc.
I would like to find out why there is a discrepancy.
Thank you for the follow up, I would like to know what is correct....
-F
Old May 16, 2012 | 12:56 PM
Me too. I will be at the dealer later today>>
Old May 16, 2012 | 02:11 PM
1st amg's Avatar
SLS Irridium silver,2014 GL350 BT Irridium, 2015 White Dodge RAM Hemi Quad
My brother "Coladin" on this forum can vouch for this, a couple of years ago he had a 2008 G37S and we were doing a winter and summer tire swap on his driveway and I had incorrectly adjusted the torque setting on the torque wrench to 135lb/ft and I snapped a lug nut off his rear wheel....we were in awe, couldnt believe I twisted that metal with a silly miscalculation, so please guys find out for sure....it was a real biatch to get that piece out of the hub.
Old May 16, 2012 | 04:00 PM
Here is a copy of the update:
Old May 17, 2012 | 02:48 AM
Faraz's Avatar
Thanks!
I will have them try and look it up again. Im sure the MFR settings are ok for a while.
Appreciate the info and the pics, North.
-Faraz
Old May 17, 2012 | 04:27 PM
Faraz's Avatar
No go, I asked my dealer again, and showed them picture- they did a lookup and found no SB - they also stated that there should be a service bulletin #.
Im going to leave mine at 96ft/lb until I can get a solid answer
-f
Old May 17, 2012 | 04:32 PM
bhamg's Avatar
C63 AMG
-f
A wise decision - I think the likelihood of 132 ft/lbs being the correct torque value is close to zero.
Old May 17, 2012 | 05:01 PM
LangeOne's Avatar
For what it's worth, my service rep worked on my BS this past Tuesday. He confirmed that, for our cars, the correct value is in the 130 lb-ft range. However for the non BS C63, the value is in the 90's.
Old May 17, 2012 | 05:28 PM
rage2's Avatar
C63 BS, GLA45
The 132 ft-lbs value is specified in the manual on page 257 of the Black Series owners manual.
Old May 17, 2012 | 06:56 PM
gthal's Avatar
2012 C63 coupe
-f
So the photo of the MB service document in post #12 isn't enough to convince you? It isn't a service bulletin if you look at it so it likely doesn't have a number. I would place much more relevance to a MB document than the fact that your dealer hasn't heard about it.
Old May 18, 2012 | 05:15 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
That value sure sounds really high. I wonder why.
