C63 AMG (W204) 2008 - 2015
Quick Spare Tire Question
Old Jul 12, 2012 | 09:49 PM
SheryarYO's Avatar
C63
Hey guys. I looked at my spare tire for the first time today and saw that it's a dinky little donut. In the off chance that I ever get a flat, I'm thinking about picking up a full size OEM rim. Since they are staggered, I wanted to know which one I would be better off getting.
I figure the rear tire is more likely to go flat than the front from wear, but if I were to get a full size rear tire as the spare, would I also be able to put that on the front in case I ever need to? Or would it be better to just get a front wheel, because I am assuming I can put that one on the back in case that goes flat. Thanks!
Old Jul 12, 2012 | 11:27 PM
JimmyR's Avatar
E63S
There was someone on here not so long ago ? last week looking to sell an OEM wheel as a spare.
Old Jul 12, 2012 | 11:46 PM
SheryarYO's Avatar
C63
that's fine, but I'll probably just get a new wheel from a dealer. my question really is if it's ok to use either the front size rim on the back or to use the rear size rim on the front for a bit when getting a flat.
Old Jul 13, 2012 | 07:32 AM
JimmyR's Avatar
E63S
In theory having different sized wheels on the rear would not do the differential much good. However as a get-you-home measure and assuming you did not do tight turns with the power on I reckon you would be fine.
Old Jul 13, 2012 | 08:44 AM
VaclavSV's Avatar
2012 C63 AMG Black Series
I used the spare on the rear... there were no issues. I looks hilarious from the back.
Old Jul 13, 2012 | 09:36 AM
SheryarYO's Avatar
C63
yeah i figured if you can use the little donut spare on the back, then you should be able to use a front size wheel spare on the back as well...correct?
Old Jul 13, 2012 | 09:50 AM
Fung63's Avatar
my wife bananas! :D
if you are set on getting a full tire as a spare. go with the front tire spec. Reason being is that you can put the front specced tire in the front or rear and have no problems to get you home. the other way around and depending on your staggered setup you will get rubbing etc.
Old Jul 13, 2012 | 09:56 AM
SheryarYO's Avatar
C63
thank you that's exactly what i needed to know
