Some pictures of my Weistec 3.0 garage build
Link to the quote: http://www.weistec.com/m159buckets.html
By now many have heard of the issue of accelerated wear in the valvetrain of the M156 engine. The materials design of the valvetrain components results in repeated contact of soft metals with hard metals. Eventually this can result in premature wear of the valvetrain, degrading engine performance or even causing engine failure.
Many M156 valve buckets are prone to "bleed down" resulting in excessive valve lash during cold start up, commonly heard as a loud tapping noise until the engine fully reaches operating temperature. Excessive valve lash is a major contributor to accelerated valvetrain wear. The M159 engine, used in the SLS and SLS roadster, features valve buckets that are of an improved design. The M159 valve buckets feature an anti friction coating to reduce wear on the camshaft lobes. They also have an improved hydraulic system that will not "bleed down" like the M156 valve buckets. Installation of M159 valve buckets will help prevent any premature wear to your engine's valvetrain and make for a quieter engine on cold starts."
My car was very prone to the start up tapping as I drive it once or twice a week at most.
The headers are custom made headers. They are mild steel and ceramic coated with a 2inch internal diameter of the primaries into a 3inch collector.
The inlet manifold.
We then went ahead and stripped everything of the front of the engine. There are quite a few interesting channels left.
Valve cover off showing the camshafts as well as the variable cam timing adjusters.
This is the point we got more or less stuck and where the expensive special Mercedes tools are required. We sorted most of the cam placement problems etc without needing the tools but with the cam adjusters pictured below a tool is needed to hold those fine gears together at a exact place prior to removal. We pondered for a while and devized a home remedy which we will be attempting on our next engine strip session.
Since we had some prep to do with the cam removal we spun the motor around and removed the oil sump. We where really shocked when we saw the size of the oil pump. The oil system is overkill in this car and the oil pump alone weighed close to 5kg. My engine builder mentioned that after seeing this the dry sump system on the SLS was either fitted to lower the motor or for just having something nice on the sales prospectus.
At this point we called it a day.
Compared to a BBC (big block Chevy) with a standard pan holds 5
The pan still needs crazy baffling either way.
A well designed wet-sump system may actually perform better than an OEM grade dry-sump system.
Anyone know if the SLS has external scavenge pumps like a true race system?
Kudos to AMG on this.
Merc63, the cam gears look like they split and this is part of AMG's honestly brilliant design. The thinner gear is spring loaded to keep constant back lash for near perfect timing and harmonics between the crankshaft and cams. When you remove cams those must be locked in place.
Nice job once again George. Let us know if we can assist at all. Thanks.
Weistec Engineering
Weistec Engineering
