C63 AMG (W204) 2008 - 2015
Supercharged C63 wheel and tire help.
Old 07-31-2012, 02:38 AM
C63_SantaFe's Avatar
C63 AMG W204
i just supercharged my 2011 C63 and it is a beast. I ran an 11.79 @ 118mph at 5000 ft above sea level. I am so impressed with the Weistec blower. I am running Nitto nt555r's. 285/40/18. I am not hooking up at all of the launch. i get a 1.76 60ft while spinning and I know I can do much better than that. I have to launch from a very low stall around 1200-1500rpm. I want some wider wheels and need help. Does anyone know the widest rear wheels I can put on my car? Also any recommendations on better tires than the 555r's?
Attached Thumbnails Supercharged C63 wheel and tire help.-img_3282.jpg   Supercharged C63 wheel and tire help.-img_3315.jpg
Old 07-31-2012, 03:45 AM
Even Money's Avatar
'15 VW GTI
If you can afford the blower, you can get some custom made 17" rims from forgeline, then put some 275/40 hoosier drag radials on.
Old 07-31-2012, 09:24 AM
SLS Qatar's Avatar
2011 SLS AMG, 2009 SL63 AMG, 2008 C63 AMG(SOLD)
Excellent run although concerning the extreme conditions
Old 07-31-2012, 11:52 PM
Zeee_Q's Avatar
C63, 335i
+1 Those times are pretty good and you have a good 60'.
For wider tires you will most likely need to roll the rear fenders to accomodate the increased width. I've seen people put 355 width tires on the rear. Slicks will definitely help but make sure you do a proper burn out before taking off. You might also want to look into a skinnier front tire and losing non-essential weight from the car.
Old 08-01-2012, 12:28 AM
Merc63's Avatar
C63 AMG
Are you running headers or stock exhaust? I assume stock exhaust?
I ran headers, tune, race gas, -200lbs and did 11.9 at 118mph. DA was around 3000ft.
But on topic, like even money said, get some 17inch rims and run Hooiser dot drags, you should be able to dead hook with those.
I was dead hooking and couldn't get into the 1.7's on 60'...
Old 08-01-2012, 12:48 AM
C63 AMG W204
I have MHP long tubes and mids. I also have a weistec torque converter. I am also using pump gas 91 octane. Thank you all for the suggestions. I will check out the 17's with the hoosiers.
Old 08-01-2012, 12:57 AM
dodger63's Avatar
2013 f250 6.7 diesel
Do you have any video or a picture of the slip
Old 08-01-2012, 01:06 AM
C63 AMG W204
I have the video but I am not sure how to upload it to mbworld.
Old 08-01-2012, 01:13 AM
Merc63's Avatar
C63 AMG
Wowzers, I would have expected more from that car. DA is ****, but I run in **** DA too and im very close to your numbers with no blower...
Old 08-01-2012, 01:14 AM
C63 AMG W204
I was running a 13.05 at 106mph with a 1.94 60' prior to the blower.
Old 08-01-2012, 02:54 PM
Merc63's Avatar
C63 AMG
Same here.
Old 08-01-2012, 03:28 PM
GeorgeSmooth's Avatar
C63
The DA and the altitude are two different things. He might be at 5000ft with a DA of 9000 if the conditions are bad.
Old 08-01-2012, 05:13 PM
Former Vendor of MBWorld
VividRacing's Avatar
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
I can help you with custom wheels and fitment issues! Shoot me a PM if you're interested
Old 08-01-2012, 07:31 PM
blackbenzz's Avatar
haters crazy
I have a pair of CCW classics with hoosier drag radials for sale. But to fit you need to change your brake pads
Old 08-01-2012, 07:38 PM
Merc63's Avatar
C63 AMG
I realize that, was the OP at 5000ft altitude + DA??
I just assumed 5000ft DA. My mistake.
Old 08-02-2012, 04:58 PM
C63 AMG W204
I was at an elevation of 5000ft. I am not sure what the DA was.
Old 08-02-2012, 05:08 PM
dodger63's Avatar
What track day and time??
Old 08-02-2012, 05:11 PM
C63 AMG W204
Albuquerque Dragway. July 27th @ 10:00pm
Old 08-02-2012, 05:35 PM
dodger63's Avatar
7625 was your approx da
Old 08-02-2012, 05:39 PM
blackbenzz's Avatar
haters crazy
Old 08-02-2012, 05:59 PM
C63 AMG W204
Thanks. Here is the video of the run.
http://youtu.be/6ggEtNMHjmo
Old 08-02-2012, 06:20 PM
D2FORGED's Avatar
R350
What about something like this we did custom for a customer wanting a drag setup for his turbocharged Corvette a while back?
Old 08-02-2012, 07:09 PM
Merc63's Avatar
C63 AMG
Wow, thats brutal, I retract all my previous statements. I thought we had it bad here at 4700ft DA.
Your racing on Mount Everest lol.
CCW will do 17 inch rims for 1000$.
I got lucky and found some knock off 17s for 200 bucks woo. Def get Hooiser DOT drag radials. They are really good.
Old 08-13-2012, 01:08 PM
C63 AMG W204
Will 17's fit over the rear rotors? I have the p31 package and I am not sure of the size of the rotors.
Old 09-25-2012, 07:32 AM
D2FORGED's Avatar
R350
Maybe the best idea would be our FMS wheels, they start from 18's to above, price range is similar, custom fitment is included.
Quick Reply: Supercharged C63 wheel and tire help.
