C63 AMG (W204) 2008 - 2015
Sigh, got a nail in two month old tires
Old Aug 27, 2012 | 09:29 AM
noodleman's Avatar
2014 E63S Wagon
Gonna take it to the tire shop this week to see if it's patchable. At least it's still holding air for now...
Sigh, got a nail in two month old tires-621021_10151118552667280_565818323_o.jpg
Old Aug 27, 2012 | 09:39 AM
Brunt182's Avatar
2009 C63 P30
Looks to be in an area that can be plugged.. It's typically only in the sidewall that would be cause for concern.
Old Aug 27, 2012 | 10:12 AM
Mort's Avatar
That should be easy to repair. Make sure the tire will maintain its speed rating or at least be aware if it doesn't.
That is a screw not a nail.
Old Aug 27, 2012 | 10:27 AM
noodleman's Avatar
2014 E63S Wagon
haha, i just noticed the robertson screw head. Good eye!
Old Aug 27, 2012 | 10:42 AM
VaclavSV's Avatar
2012 C63 AMG Black Series
Get it patched from the inside! I had a much worse bolt in my PSS earlier this year (funny enough after 1.5months!) Take it to Simply Tire and Allen will patch it from the inside. I have been very hard on the tries since and the patched one is still holding up extremely well!
Old Aug 27, 2012 | 10:47 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
U r lucky noodleman, a few mm on the left & u can kiss goodbye it brand new tire.
On the other hand, the screw might be very short to the point it never went through.. Lol
WBE55's Avatar
2002 E55 AMG, 1999 E55 AMG , Audi allroad 2.7T sold ,08 Jeep SRT8 sold, 06 TBSS Sold
Youll be fine that's an EZ fix. Do you have a tire warranty ?
Old Aug 27, 2012 | 11:35 AM
Vic55's Avatar
Administrator
Patch it, do NOT plug it- its far enough off the sidewall.
Old Aug 27, 2012 | 12:06 PM
noodleman's Avatar
2014 E63S Wagon
it definitely went through, as it was completely flat when i checked on it last night. I was able to pump air back into it and it held pressure. I'll just have to keep checking the tire pressure when i drive until I can make it out to the tire shop to get it fixed.
Old Aug 27, 2012 | 12:13 PM
HoozyerdaddyC63's Avatar
C63
Sorry about your tire, but do you have some pics of your wheels? I've been checking out different wheels for next summer. Thanks!
Old Aug 27, 2012 | 05:31 PM
shades's Avatar
09 C63, 11 Cayenne S
Sorry to say my friend but that tire is not repairable. It is too close to the sidewall. Any shop that repairs tires properly will tell you to get a new tire. Keep in mind that there are many shops that will fix it but it's not safe because the patch/plug will roll over to the sidewall and can potential peel off. I know it's a pain to buy another tire but I've seen it happen many times where guys say it will be okay, but do you want to be the one who says that and have a bad blowout on the 401 all because of a $280 tire? It's not worth it bro, believe me.
Old Aug 27, 2012 | 05:58 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
+1 Definitely patch it rather than plug it if repairable.
Old Aug 28, 2012 | 03:02 PM
noodleman's Avatar
2014 E63S Wagon
update: got the tire plug and patched by simplytire. Going to monitor the tire abit to make sure it's not leaking any more.
Old Aug 28, 2012 | 03:06 PM
noodleman's Avatar
2014 E63S Wagon
They are Work Meister S1Rs. here's a couple of pics of them
Old Aug 28, 2012 | 03:26 PM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
Eh, don't be too bummed. I was waiting for these tires to go before I bought a matched set of Michelin SSes. Since the rear Vredesteins were wearing faster than the front Toyos, I had to replace them. After I special ordered them online and was having them mounted, I asked the tire shop to rebalance the front. They showed me a gash in the sidewall of one of the front tires.
So ultimately, if I knew about the gash (must not have been bad enough to leak air, but imminent) I would've just sprung for a full set of matched Michelins instead of the exact same tires I already had
Old Aug 28, 2012 | 10:18 PM
c63edition1's Avatar
2013 Fiat Abarth
ill try to make u feel better with these 2 stories ..
1.. someone slit my sidewall badly once, (and my friend's R8) they were parked together, but the tires had to be changed anyways.
2.. on the new tire, just 1 month old, i floored it on the light, and some piece of metal punctured the tire, and PERFECTLY hit the valve for my my exhaust system, rendering the valve mechanism useless, truly a very rare occurrence .. had to wait 2 months for a new valve as they dont make that seperate, and the hole in the tire was soo big they had to plug it with a piece of rubber about an inch thick, it still leaks so i gotta change it soon.
so, yeh :P dont feel too bad
Old Aug 29, 2012 | 08:04 PM
LFM_Vancouver's Avatar
C63s now in the garage. Sold-GLA45 AMG Edition 1, Sold-2010 Mercedes C63
I knew you were in Canada just by the screw head. Americans don't really use Robertson head screws. It's a Canadian thing, it's also better.
