C63 AMG (W204) 2008 - 2015
Question about winter rim for c63
Old Sep 25, 2012 | 09:30 PM
dacatz's Avatar
From: Richmond Hill - Markham area, Toronto, Canada
c63, prius
Trying to get some winter rims for my MY10 C63....need help...since i don't want any wheel rub....I have the tires already....the tires is Prielli Scottozero II 235/40R18
The tire shop offer me the following rim size
18 x 8 offset 35
18 x 8 offset 50
18 x 8.5 offset 45
18 x 8.5 offset 35
which one should i get to be safe in order to clear the brake and not rub the wheel well....
thanks
Old Sep 25, 2012 | 11:54 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
go 18x8.5 +45 all around.. i believe that's what MB winter wheels package offers.
Old Sep 26, 2012 | 12:02 PM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
Anyone know if there exists any plain, cheap, ordinary hubcap style steel wheels that I could throw some winter tires on, I do not want to really get another set of rims (okay, my wife does not want me to... )
Old Sep 26, 2012 | 12:21 PM
N1ck's Avatar
C63C
I'm interested in this as well. Does anybody know if 18x8 et 35 would fit our cars without any clearance issue?
Old Sep 26, 2012 | 01:36 PM
late_bloomer's Avatar
2012 c63 sedan
I am considering ordering these winter tire/ rim setup from Tirerack..Many rims to choose from.
http://www.tirerack.com/snow/WinterW...&Qty6=4&Qty7=4
Old Sep 26, 2012 | 04:55 PM
Mort's Avatar
Sorry you link is broken.
Old Sep 26, 2012 | 07:49 PM
dacatz's Avatar
c63, prius
i just want rim only...i have checked tirerack but they only have two choice of rim for the winter setup...that y i have to find a local shop to get me the rims!
Old Sep 26, 2012 | 10:42 PM
Chocofishez's Avatar
2014 E63 S
I'm looking at these rims and 265/235 Pilot sport alpins. Won't be DDing my car over the winter just running it on dry days.
http://www.oemwheelplus.com/mercedes...ims-p-473.html
All the tire rack options are 19 inch... They gotta fix that.
I have a set of oem all seasons from my wife's c350 that I'm tempted to try first tho... Even with everyone telling me not to!
Old Sep 26, 2012 | 10:46 PM
andrew c230k's Avatar
W204 C63 R171
http://www.puremb.com/forum/showthre...-Rims-Fitment-!
Old Sep 27, 2012 | 12:00 AM
dacatz's Avatar
c63, prius
do we have enough clearance to install spacer?
Old Sep 27, 2012 | 12:02 AM
dacatz's Avatar
c63, prius
no steelies will fit because of the calipers....only alloy rims!
Old Sep 27, 2012 | 12:09 AM
Roswell's Avatar
Welcome to the club of married man who can't mod their cars anymore.
Old Sep 27, 2012 | 12:20 AM
oggie's Avatar
2011 E550 4Matic & 2010 Audi Q5 & 2015 C63 507
I was always under the impression that there is a trade-in program....
Old Sep 27, 2012 | 11:29 AM
jvanbrecht's Avatar
It got even worse when the baby came around (4 month old now)... now instead of tires.. I am buying diapers by the dump truck load.. (yes there was an intentional pun in there )
Old Sep 27, 2012 | 02:04 PM
2012 c63 sedan
Oops.. When you are on tirerack.. pick your vehicle as 2012 c350 sedan and pick 18" winter rim packages.. You will see ~100 rims to choose from..
I am thinking of getting these rims..Does it work ?
http://www.tirerack.com/wheels/Wheel...65&PID=4178170&
Old Sep 27, 2012 | 02:09 PM
Even Money's Avatar
'15 VW GTI
you guys don't need winter rims....just get some vredestein wintrac extreme. I think it's 245 and 265. Yeah it's staggered, but works great. I never had an issue in the Pac NW with several snows. Ice was another issue, but that'll get anything but studded tires. Plus they handle very well in the cold and wet.
Old Sep 27, 2012 | 02:22 PM
W204 C63 R171
factory summer is
18x8 ET 45
18x9 ET 54
factory winter is 18X8 ET45
with ET 45 wheels you will have room to run spaces but why would you want to?
With my setup that allows you to use all older style Mercedes spec wheels 18X8.5 ET 35 will not allow the use of spacers and is not needed there is plenty of room between the spoke and caliper the issue is the wheel barrel is very close to the front caliper. These older spec mercedes wheels are the ones that everyone will tell you wont fit and you have to buy newer ET wheels...
I had this same problem last year going to tireshops trying to find something suitable.
Personally since ET 45 wasn't an option for me at the time they where all sold out, a friend of mine had those brabus s replicas so I got them from him test fitted and low and behold they work.
My summer setup is 19X8.5 ET 35 and 19X10 ET 60 with a 5mm spacer to bring its overall ET to 55
If I was doing it again I would still try and buy a wheel as close to factory setup as possible so my choice would be 18X8 ET 45 all around but depending on the replica company, the way the spokes are designed and the wheel barrel you might run into issues.
BTW yes tirerack has alot of wheels to choose from however 90% of them are not hubscentric and will leave you running hubcentric rings and other garbage.
Old Sep 27, 2012 | 02:28 PM
W204 C63 R171
Reason alot of us run winter rims as it protects your summer wheels from salt corrosion and bends from the pot holes that develop due the winter conditions in Canada.
Personally I don't like anyone working on my car so to have someone mount and unmounted tires 4 times a year would probably lead to your expensive Mercedes rims getting and screwed up because there are very few people that know what they are doing and do a good job as if it was there own car they where working on.
I also enjoy being able to put them on when ever I want not having to make appointments waste time going to a garage. I just pull out my jack and impact gun and in 30 mins I am all ready to go for winter and 100% A1 perfect job every time never leaves me disappointed or relying on some kid that gets paid minimum wage to work in a garage and install tires.
Old Sep 27, 2012 | 02:34 PM
Even Money's Avatar
'15 VW GTI
No worries there...in that case, use the stock rims for the winter, and buy something for the summer. I think that makes more sense.
Old Sep 27, 2012 | 02:52 PM
W204 C63 R171
for winter traction its better to have same width wheels all around. I get what your saying but its harder and alot more expensive to get those tires your recommending here in Canada... just like everything we buy its cheaper in the United States
Old Sep 27, 2012 | 03:11 PM
2012 c63 sedan
On my link to rims, how do you tell if it is hubcentric or not? Does not state on specifications, unless I am reading it wrong. I am new to rims, can you explain 'other garbage'? I want to order soon, but don't want to mess anything up.. Thanks in advance
Old Sep 27, 2012 | 03:23 PM
W204 C63 R171
Look under included hardware, they require hubcentric rings. My understanding is these type of wheels are made for a wide variety of cars and they give you special rings that center it up for you specific vehicle...
(20) Required lugbolt for vehicle
(4) Required centering ring
"Listen to me very carefully. There are three ways of doing things around here: the right way, the wrong way, and the way that *I* do it. You understand?" ~ Ace Rothstein
Personally I wouldn't run anything that's not properly made for my C63 on my C63
Old Sep 27, 2012 | 03:56 PM
2014 E63 S
Except we have C63s, not C350s... much bigger brakes. I'm worried about the clearance as the OEM 18s have very little room...
When I go on tirerack and select 2010 C63 I get ten wheel types and they're all 19inch wheels.
Makes me a bit worried that the OEM 18s are a special design to clear the calipers, and so only the 19s fit on other brands?
Old Sep 27, 2012 | 04:04 PM
2012 c63 sedan
Hmm, you may be right.. If you select 2011 c63 sedan and winter package, I believe there are 3 rims available. Starting to hurt my head on getting rims..
Should I just buy nice rims next spring or cheapos now.. decisions..
Old Sep 27, 2012 | 04:08 PM
W204 C63 R171
The oem 18 have a flat inner wheel barrel some aftermaket have steps in them... that why my old authentic brabus 18" wheels wont fit on the C63 there is a step in the wheel barrel that hits the caliper.
