C63 sedan exhaust sound
Guys can any one help me know which part exactly wants to be replaced in my upcoming 2013 c350 sedan to have the same sound of the C63 ? But i want OEM parts , and if u can help me with part number and where i can buy them online ..thankss
just install two more cylinders at the appropriate firing order.
2011 C63 Calcite White
impossible to get the AMG note without the AMG engine lol, even if you have the AMG exhaust it won't. But many ways you could make your car louder that's for sure
A li'l off topic, but getting an AMG not is not easy. I have a 6.0L GTO (since 2007) and I can have a deeper note or a louder rumble or heavier pitch but I couldn't replicate the AMG note.
So I'll reiterate my point, you need part no: M156.
Should be about $20,000 plus you'll have to widen the front of your car to fit that in there.
Good luck.
Good luck.
Good luck.
Good luck.
2009 C63
Just test drive a C63, record the sound and burn a CD. Get back in your car, open all the windows and drive around with max volume (push "Pause" at red lights)!
2011 C63 AMG, 2011 Z4, 2013 BMW 335
Since your car is a V6 and a C63 is a V8, I do not think an OEM stock C63 exhaust is going to simply bolt on to your car. You will need to modify it (if you have somebody skilled enough to do it). I would think the modification would change the note so you won't get a C63 note anyway.
If I were you, I'd find an after-market exhaust system for the C350 that you like and go with that...or just buy a used C63 for the same money
