Sidewall damage, mixing tires, and PSS?
I already mix tires, PSS in the back and Conti DW up front because when I switched rears to PSS the fronts looked basically new still. Anyway, is it safe to mix tires up front? I still have a OEM P-Zero front driver side. They're both performance summers so they would be the same type, although my PZero is 235 and I'm pretty sure my ContiDW is 245. I'm guessing this is bad, but how long would I be able to safely get away with it?
And finally, for all my PSS people, what sizes are you running for PSS in the front?
Sorry for creating a new thread, thought this would be better than digging up 3 separate threads about 3 different things.
It is not recommended to mix tires on the same axle, especially if they are different sizes.
I am running PSS 275/30/19 on the rear and 245/35/19 on the front.
GL and sorry to hear about your tire damage. Check to see if you have road hazard coverage on that tire?
As for different size tires, if temporary it should be fine but just be careful driving in the rain cuz if both tires are different brand, they will have different thread pattern that might cause your car to be unbalanced.
