C63 AMG (W204) 2008 - 2015
M156 V8 6.2L Vs Ferrari V8 4.5L
Old Oct 12, 2012 | 01:28 AM
mainly's Avatar
Porsche 991 GT3, 2012 cls63 Kleemann K3
Originally Posted by 34.50
Don't know about you guys but I think Ferrari have a **** exhaust note. It just sounds like a high pitched whiny engine. I like the deep growl of the AMG, now that's an exhaust note
-1
Old Oct 12, 2012 | 07:58 PM
b16's Avatar
b16
2009 C63, 2000 ML 430, 1994 Del Sol Vtec
Originally Posted by shchow
I think you got it reversed.
The CROSS-PLANE engines are imperfectly balanced and need counterweights.
The SINGLE-PLANE engines are better balanced and do not need the extra weights and revs much more freely and has a very characteristic engine note.
The sacrifice in the single plane engines is probably durability...
It is the combustion events that is off balance; per-se.
Old Oct 12, 2012 | 08:26 PM
shchow's Avatar
2014 CTS-V (6spd, phantom grey), 2010 Cadillac Escalade ESV (black raven)
Yes, it's the sequence on how the cylinders are fired.
The flat plane (single plane) crank is better balanced, and lighter without the need for counterweights, and revs more freely.
These are found in all the Ferrari engines.
They're more raucous and probably not as durable.
I was at an auto event and asked one of the engineers why M, AMG, S don't use this type of engine.
He said those buyers still expect some degree of civility, and the flat plane cranks are probably not as durable.
Old Oct 12, 2012 | 08:32 PM
Andrew Roberts's Avatar
2008 C63 Sedan, 2018 C63S Coupe, 2018 E63S Estate
Originally Posted by Swoody
Not really, that intoxicating sound comes from their "flat plane crankshaft".
The flat-plane or single-plane crankshaft has crank pins at 180°. They are imperfectly balanced and thus produce vibrations unless balance shafts are used, with a counter rotating pair flanking the crankshaft to counter second order vibration transverse to the crankshaft centerline. As it does not require counterweights, the crankshaft has less mass and thus inertia, allowing higher rpm and quicker acceleration. Flat-plane V8s on road cars come from Ferrari (every V8 model they ever made, from the 1973 308 GT4, to the new 458), Lotus (the Esprit V8), TVR (the Speed Eight) and McLaren (the MP4-12C). This design is popular in racing engines, the most famous example being the Cosworth DFV.[16]
The HP per liter is a function of it's direct fuel injection, compression ratio (12.5:1) & RPM...
Interesting - thanks for the info.
Old Oct 12, 2012 | 08:55 PM
mainly's Avatar
who expects civility? not me.
i assume Lamborghini's have this too.?
too bad you have to pay 2-300,000 dollars to have this.
Old Oct 12, 2012 | 08:59 PM
Guilty's Avatar
'16 C63-S
+111
