Car running very hot! -Possibly due to low coolant?
Subscribe
Oct 19, 2012 | 11:16 AM
Hi guys so last week I got a "Check coolant level" warning as shown in the picture below. My C63 is a 2012 sedan with just over 30000kms. The warning comes on usually when I start the car when its completely cold... so really only in the mornings, but not every morning. Last night I was driving and noticed my temperatures which are usually somewhere at 92/92 C was reading 110/92C and I wasnt driving very hard! I started to drive in C mode and be easy on accelerating and it came down to 103/92C. I have an appointment with the dealer next week Friday. Should I add coolant myself? is it difficult? What could be causing these issues? Any advice would be great! Thanks!
Reply 0
Oct 19, 2012 | 11:23 AM
Yeah it's because of the coolant. My temp got a little high when my coolant level dropped. Just walk-in at the dealer and they'll add coolant in the drive-thru... You don't need it an appointment for that
Reply 0
Oct 19, 2012 | 11:40 AM
If you're comfortable with the levels, you can do it yourself. Otherwise any dealership should do it without much hassle. While you're there, you. Can ask if your engine number is on the head bolt list. That way you know if you should be keeping an eye on the coolant level.
Reply 0
Oct 19, 2012 | 11:54 AM
I get the same message once in a while.
Cold morning, starting engine and "check coolant level" pops up.
I haven't noticed a higher engine temp though.
Reply 0
Oct 19, 2012 | 12:32 PM
Quote: Should I add coolant myself? is it difficult?
Open hood. Open coolant reservoir. With cold engine, fill coolant up to the mark on the tank. Button it up. Done.
Or, like Guilty said, hit the drive-thru at your dealership.
Reply 0
Oct 19, 2012 | 12:38 PM
Where do I purchase the coolant? What coolant is needed?
Reply 0
Oct 19, 2012 | 12:42 PM
Quote: Where do I purchase the coolant? What coolant is needed?
Some guys would just pee in it to fill it up... I've seen it done.
I would go to the dealer and buy some... or a local auto store.
Reply 0
Oct 19, 2012 | 12:47 PM
Quote: Some guys would just pee in it to fill it up... I've seen it done.
+1. Follow the mixing instructions on the bottle, keeping in mind that a higher concentration of coolant-to-water will make your engine run hotter.
Reply 0
Explore
Oct 19, 2012 | 12:51 PM
Is there a particular brand?
Reply 0
Oct 19, 2012 | 01:28 PM
OEM. Don't mess around.
Reply 0
Oct 19, 2012 | 01:33 PM
Quote: OEM. Don't mess around.
what is the OEM brand?
Reply 0
Oct 19, 2012 | 01:34 PM
Mine runs at 105 and 92
Use MB approved or MB coolant.
Purchase at dealer.
Or top up with distilled water... As long as the level is not too low.
Reply 0
Oct 19, 2012 | 01:37 PM
Can't you just top up with some distilled water if its not to low?
Reply 0
Oct 19, 2012 | 02:07 PM
Quote: Can't you just top up with some distilled water if its not to low?
yes. but like you said, as long as it's not too low, otherwise it'll affect the concentration. it would have to be pretty low for that to happen, though.
Reply 0
Oct 19, 2012 | 02:19 PM
50/50 is cheap. Just use that instead.
Reply 0
Oct 19, 2012 | 03:55 PM
Quote: 50/50 is cheap. Just use that instead.
Probably best to use the OEM coolant from the dealer. You know how hot our engines run. Use the best.
Reply 0
Oct 19, 2012 | 03:58 PM
Fair enough. My point is go ahead with proper coolant and not just water, if you're going through the trouble anyway.
Reply 0
Oct 19, 2012 | 04:57 PM
your wagon is super sexy...nice car!
Reply 0
Oct 19, 2012 | 05:46 PM
Looks to me that it is VaclavSV's oil temp that is going up and not his coolant temp. It seems pretty normal for the oil temp to go up if the car is pushed a bit. My normal driving around temps are 101*C(oil)/91*C(coolant). Doesn't look like the engine is running hot to me. Just get the dealer to top up your coolant reservoir and check your oil level and you should be good to go. It is easy to fill the coolant reservoir yourself but why do it when the dealer should do it for free and you will not have to buy a $45 (last I paid from memory) jug of coolant.
Reply 0
Oct 19, 2012 | 09:48 PM
Thanks guys. I got the coolant topped up at the dealer. Everything seems normal.
P.S. Looking forward to the meet tomorrow afternoon!
Reply 0
Oct 19, 2012 | 11:44 PM
You watched another dude **** into his coolant over flow?!
What else did u two do after? LOL
Reply 0
Oct 20, 2012 | 03:09 AM
Does coolant level dropping = head bolt issue?
Reply 0
Oct 20, 2012 | 03:52 AM
Not necessarily.
Reply 0
Oct 20, 2012 | 10:00 AM
I dont know. My car is running strong right now.
Reply 0
Oct 20, 2012 | 11:14 AM
Quote: Does coolant level dropping = head bolt issue?
VaclavSV car is a 2012 and should not have the head bolt issue as it should have the updated head bolts from the factory. Our '08 R-Class 320 CDI used a little coolant with no obvious coolant loss. In three years I had to top it up 3 or 4 times with a cup or two of 50/50 mixed MB Coolant. It was a lease so at lease end I just turned it in.
Reply 0
Subscribe
Currently Active Users (1)
