C63 AMG (W204) 2008 - 2015
How to do Oil Change on your C63 at Home!
Old Feb 28, 2016 | 03:48 PM
  #101
tdk930s's Avatar
2011 C63 P31 LSD
today try to change oil the first time ,having a hard time to locate the oil drain plug and the pictures from here doesn't show anymore. Can somebody help show where the oil drain plug is locate? Thanks for help.
Old Feb 28, 2016 | 04:10 PM
  #102
65fastback's Avatar
amg c63
Get off the computer & back under your car! i am sure if you look at the oil pan long enough you'll find it.
Old Feb 28, 2016 | 07:48 PM
  #103
Mort's Avatar
It is on the drivers side of the pan near the front of the pan.
Old Feb 28, 2016 | 09:32 PM
  #104
tdk930s's Avatar
2011 C63 P31 LSD
Yes find it ,thanks.
Old Apr 20, 2017 | 09:55 PM
  #105
brad65ford's Avatar
2020GLC63
Damn old thread but figured i'd keep it here since there seems to be some discrepancy on suggest/recommended amount of oil required with out and with removing oil from also the cooler. Recently did an oil change with out removing oil from cooler (which i did) and filled the engine with 9.5 quarts. The level after running the car up to normal operating temps is over the top red mark. Wishing i removed the cooler oil but didn't.
Old Apr 21, 2017 | 10:25 AM
  #106
Mort's Avatar
Now you know that is not the way to fill your sump after doing an oil change.
Fill it to slightly below stated capacity (say 8 liters/quarts), start it up so the oil is distributed throughout the system by running it for a couple of minutes. Shut it down and let it sit for half an hour. Check the level on the dipstick and then fill it in small amounts until you get the correct oil level on the dipstick that you are looking for.
You should correct the oil level. I have run mine to the top of the red marker but cannot recommend it. If it is too high the crank lobes will run through the oil and that is not good.
You can take it to someone to correct the level or do it yourself.
1. Get a vacuum device and a long tube and suck what you need to correct the level from the sump through the dipstick tube.
2. Remove the drain plug from the oil cooler and drain the oil that is in it and hope that gets you to the required level. That should remove less than a quart. If it keeps coming reinsert the drain plug. I think only the oil in the cooler will drain, but be prepared for more. Pressure will be low and it will be relatively easy to reinsert the drain plug if necessary but a bit of a difficult spot to work in.
3. Pull the drain plug on the sump and let some oil drain out. This will work but can be messy and the drain plug a little hard to control and restart. Keep a good grip on the plug at all costs and be sure to position yourself so you can get the plug reinserted as the oil pressure and circumstance will make it difficult.
GL
Old Apr 21, 2017 | 10:28 AM
  #107
brad65ford's Avatar
2020GLC63
Thanks GL, been bothering me since i did it. Will try removing some oil from the cooler. Can't believe i did this, wondering if this was the reason it was pinging with the first attempt of the v6 on 93 octane.
Old Apr 21, 2017 | 10:33 AM
  #108
Mort's Avatar
The crank running through the oil and causing it to splash around in the sump may in fact be the pinging you heard.
LOL......GL = Good Luck
Mort
Old Apr 21, 2017 | 10:34 AM
  #109
brad65ford's Avatar
2020GLC63
Live and learn live and learn
Old Apr 21, 2017 | 10:49 AM
  #110
brad65ford's Avatar
2020GLC63
Ok she's up on the lift and covers off, where the heck is the oil cooler nut. I see the oil cooler or at least what i think is on the right side, right?
Old Apr 21, 2017 | 10:54 AM
  #111
brad65ford's Avatar
2020GLC63
scratch that request i see it lol.
Old Apr 21, 2017 | 11:02 AM
  #112
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
You don't even need a vacuum device... all you need is a small diameter flexible hose (like the medical stuff they use for IV drips) that will fit down the dipstick tube and a container to collect the oil. If you've ever siphoned gas out of a car, the same principle and method will work. Sure, the flow rate is goign to be much lower and you won't be able to get all of the oil out, but you're only trying to take out a liter or so and this shoud work... at least it did many moons ago when I accidentally ovefilled the P-car track rat at the track and needed to remove a few liters without having much in terms of tools. Oh, and make sure you don't do it when the engine is hot enough to melt the tube or you're going to haver much bigger problems... but it definitley works on a cold motor. GL.
Old Apr 21, 2017 | 11:45 AM
  #113
brad65ford's Avatar
2020GLC63
That is a good idea too. I removed what was in the cooler once then started motor then did it again. Looking at the dipstick I'm still to high. Thinking the cooler only holds less then a quart guessing. I installed exactly 9 1/2 quarts when i dropped all the oil from the sump and new filter.
Old Apr 22, 2017 | 03:12 PM
  #114
Diabolis's Avatar
You overfilled by about a liter (9.5 quarts = 9 liters). Without draining both of the oil coolers (the second one is in the right wheelwell), you need about 8 liters of oil if you drain the sump alone.
Old Apr 22, 2017 | 04:09 PM
  #115
brad65ford's Avatar
2020GLC63
agree, today we used a hard plastic tube and inserted down the dipstick tube and sucked out 1 quart. Oil reads in between the two marks now. Have a feeling its 8 1/2 to 9 quarts max with all oil from sump and cooler removed as well as new filter.
Old Sep 1, 2019 | 05:48 PM
  #116
C63AMG650's Avatar
C63 AMG
https://www.redlineoil.com/0w40-motor-oil
Redline oil beats other oils hands down and it is MB Certified as well as others. I use it in my Harley too.,
0W40 MOTOR OIL
  • Suitable for VW/Audi 500.00/502.00/ 503.01/505.00, BMW LL-01, water-cooled Porsche A40 and Mercedes-Benz 229.3/229.5 applications
  • Used in Dodge Viper and many later Chryslers (MS-10725)
  • Better flow at extremely cold temperatures compared to 5W40 and 10W40
  • Recommended for API SN/SM/SL/CF and ACEA A3/B3/B4
Old Oct 22, 2019 | 03:27 AM
  #117
yeswife's Avatar
C63 Coupe 507 Ed
Hey all,
Im about to do this on my 2015 C63, could someone advise best place to jack the car up and where to put the stands ?
