Help: Low Dyno Results
The runs were done on an intertia dyno (I'm not sure if its the right name for it)
Any ideas what could be the cause?
I am planning to finally do a tune this winter and would like to sort things out beforehand.
Thanks in advance
RWHP:
also, help us out by converting to whp/tq, not sure which numbers to use from your chart..
Temp was about 20*C / 68*F
One fan.
I edited my first post - shows WHP, temperature and torque.
Go back for some more runs to see if it's consistent. Any other 63s use that dyno? And when you get your tune, go back again. If you have a good delta, then that's all that matters, provided the car is running right.
I know about the mustang dyno but the guy at the shop told me that the readings here are usually accurate and that 30 horses getting lost is not normal.
It seems to me that the car is running fine but it's difficult to notice the difference (-30whp) when I drive the car all the time and most of the time in the city.
P.S. My tires were almost bald.
just make sure you put it on the same dyno after the tune. to see the gains
one other question, whi is the graph sloping at low RPM, were your tires slipping?
The tires were not slipping.
To be honest I am usually very skeptical about the skills of such workshops in Poland but every petrolhead I know advised me to use this dyno.
In which gear should we do the runs?
4th or 5th ?
Prindone:
The car has 146'ooo km.
The dyno showed 420PS.
4th or 5th ?
Prindone:
Do the runs in 4th gear.
When you take it next time set your rear tire pressures @ 36-38PSI
Dont forget to set your C63 on Dyno Mode from your interior commands, do you know how to do that?, did you do it on your last dyno run?
I'll try in 4th gear next time- last time we did the runs in 5th gear.
The tire pressure was 40PSI.
edit: nevermind...
https://mbworld.org/forums/c63-amg-w...ep-method.html
edit: nevermind...
Anyone tried this?
P.S. I'm a big fan of your estate. The drop and front is *******g sick.
4th or 5th ?
Prindone:
I Could tell you that it can be possible, mine too was about this power before i tune m'y ecu.
This Is normal m'y Audi RS4 B7 was about 370 instead of 420ps because of the oil circulation tank that Is a big problem on this car.
The car is Never about the power the manufactur say, just the GTR pass the power that Nissan say they have original!
(and If they say this its just for the law like this not too much taxes in Europe)Dyno mode??? Could someone explain more about it, im interested?
Here is how You get into dyno mode:
