- Mercedes-Benz C-Class: Buying Guide
Important information to help you understand your Mercedes-Benz
Browse all: Specifications and General Maintenance
C63 Head Bolts and Engine Repair
1. Thou shall not bring a go pro camera into the car
2. Thou shall not pass your instructor's car
3. Thou shall not hit your instructor's car
4. Thou shall not turn off the ESP
5. Thou shall not switch to manual mode
6. Thou shall not use the paddle shifters
7. Thou shall not get lost on the autocross course
8. Thou shall not get airborne in the corkscrew
9. Thou shall not covant thy neighbors' ceramic brakes
10. Thou shall not drop the top on the SL63 or SLK55
11. Thou shall not use the skip pad to practice your drifting skills
12. Thou shall not rat out your co-driver's errors
I just posted the pics of the damaged head and head bolt:
https://www.facebook.com/mrtazzymotorsports
Look for "The C63 damages"
I tried getting a direct link but it didn't work.
When you lawyer up and start suing, the only result is that MB will lawyer up as well, and this can go on for ages. If everyone that has had an issue (probably many more then just on the board) complained to NHTSA, then MB would be forced to issue a recall, if there is sufficient evidence (I am not saying there isn't) that it is a wide spread problem.
However, considering how many M156 engines are out there, even if 100 had this problem, the percentages are extremely small, no recall may occur.
Roland,
Some of those new pictures are AWESOME!!! Look like freaking artwork! I really need to buy a new camera!
Thanks for all your hard work!
Jonathan
2.) The broken bolt was still in the block and I was not interested in trying to extract the bolt while the head was still on the block and there is not enough clearance to pull the head up high enough in order to clear the broken head bolt.
3.) The ARP stud kit was defective, one of the studs were missing the Allen head so it could not be installed while the head was on the block.
4.) Installing the head studs first is a wise choice to be sure of correct installed height. Again, there is not enough clearance to install the heads on this motor while the studs are installed in the block and block is installed in the car.
5.) You make it seam like removing the engine is a dramatically difficult procedure, which it is anything but hard to do. Once the trans is separated, it's two wire connectors, two motor mounts, two fuel related hoses and three coolant pipes and you're done.
This is not a motor you can take foolish risks with, you can't just pull pocket change out to replace it if you make a mistake like you can a Civic. I know I wouldn't want to pay some guy money to run ATF through my $40,000 motor in hopes that somehow that would clean out 18 litres of paste.
All this aside though, if you have one of these motors and it hasn't popped a bolt yet I have no doubts that you could replace the bolts with studs without even removing the heads if you know what you're doing.
We want more pictures!!! Got any of the finished motor? Sounded great on the phone!
Update for everyone:
I got a phone call from Roland about six thirty one evening last week and he said he John listen to this: insert engine roaring noise! Love it! What a great shop. Mr Tazzy rocks.
Should be good to go next week after they do all the fluid changes etc. might as well do the tranny and the diff at the same time!
Question for Roland: are you sure you can change the bolts to studs without pulling the heads? I thought the head gaskets would leak for sure?
For anyone in Ontario I would highly recommend Mr Tazzy for this job. The three guys in the shop are great.
JN
JN
The ATF trick is good for a noisy lifter or an engine that has been sitting and I would have used it if this were the case with this motor.
All the best with your Porsche motor.
