C63 AMG (W204) 2008 - 2015
RIMS AND TIRE QUESTION FOR MY C63
Old Nov 15, 2012 | 05:03 PM
flowfab's Avatar
2012 C63
CAN ANYONE HELP ME PLEASE ?
THINKING OF PUTTING VOSSEN VVSCV3 RIMS ON MY 2012 C63 AMG
8.5 X 20 X 44 OFFSET FRONTS
10 X 20 X 55 OFFSET REARS ( WITH 3MM CENTRE HUB SPACER TO CLEAR CALIPER)
TIRES
235/30/20 FRONT
275/25/20 REARS
WORRIED ABOUT FITMENT, LOOKS, IF ANY ISSUES WITH RUBBING
OR ANY OTHER COMMENTS.
THANKS
Old Nov 15, 2012 | 05:22 PM
theunderlord's Avatar
(SOLD) 05 E55 Estate. 11 Golf TDi
STOP SHOUTING.
Old Nov 15, 2012 | 05:32 PM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
^^^^LOLOL
seriously, why do newbies always have to scream their posts out...
Old Nov 15, 2012 | 06:05 PM
flowfab's Avatar
2012 C63
sorry about that I'm in the architectural business we always print in caps.
Old Nov 15, 2012 | 06:06 PM
cptdaz's Avatar
home the point
Old Nov 15, 2012 | 06:08 PM
flowfab's Avatar
2012 C63
So lets try again; can anyone give me their opinion?
Old Nov 15, 2012 | 11:36 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
From your numbers, it looks like a perfect fit. I dont think you need the 3mm spacers unless your wheels are very concave... with the 3mm spacers, your rear offest will be +52mm so it's a close fitment in the rear with 20 inch.
Old Nov 15, 2012 | 11:39 PM
AMGFANs's Avatar
12 MB C63
I think it will rub a bit for the rear...
Old Nov 15, 2012 | 11:53 PM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
Stock suspension? That makes a difference too.
Old Nov 16, 2012 | 12:45 PM
cptdaz's Avatar
home the point
If you hit a hard bump, yes it will rub. Otherwise you're fine (if you're on stock suspension). Also with 10 offset and 3mm spacer your rear will stick out quite a bit. I have 9.5 with no spacer and it's flush against the fender. Personally I hate the rear tires sticking out beyond the body, looks ghetto, but to each his own. 8.5 in the front should be fine, I have the same.
Old Nov 16, 2012 | 02:31 PM
Fung63's Avatar
my wife bananas! :D
should work out great. you can always not use the spacers afterwards.
since you are in toronto, i suggest you let me check out your car first .. and then after you install the wheels
