carbonio intake for sale
12' C63 P31, 06' Supercharged Range, 08' BMW 550i
Condition?
On their website is says that it will increase: - Power increase: 18-21hp - Torque increase: 14-18lb/ft ... is there any truth to that?
Did you notice any difference is throttle response/ speed with these intakes?
Did you notice any difference in exhaust note?
Any issues with running this on a stock ECU/ did it adjust for the additional airflow?
Reason for selling?
Thanks!
Reason for selling?
Thanks!
parting all my stuff selling car!
06 CTT-S
is this the 'natural' color or did it 'yellow' overtime? (due to heat maybe)?
also newbie question but when you installed this, did you also change the filter (to fit the bigger air boxes)? or the OEM is just fine? thanks
There is slight discoloration as all carbiono hzce dome this, stock filters size are what you use
What your seeing is the sunlight reflection on the top 2/3 of it, it actually looks like the bottom 1/3rd
^^^ buddy this is from 2012
Guys..I might be selling mine..give me 2 weeks though..BUT...One issue...CEL ALWAYS comes on..it's annoying as hell which is why I might be going back to the stock boxes..but I'm not 100% sure yet that it's the CF boxes causing CEL but I'm pretty sure because one of my MAF sensors wiggles and theres no way to make it a tighter fit..plus theres 0 sounds or anything else wrong with the car (it was just serviced) so I'm guessing it's the sloppy MAF mounting they want you to use VS using the actual clips so it's in tight..anyways I'll post back in this thread once I go get the codes...P.S there's very little performance difference...it's purely just for looks mostly..I'd recommend buying a set of straight pipes before you fork out $1k for these air boxes
honestly i have to agree ^^^^
since i have put mine on the cant get my cel light to go off
im going to change the oxy sensors if that hasnt fixed the problem
these are going for sale
ever since i put these on i have had the light on
