C63 AMG (W204) 2008 - 2015
2013 C63C Rear bumper to fit 09 C63 sedan?
Old Dec 27, 2012 | 12:52 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
2012+ C63C Rear bumper to fit 09 C63 sedan?
I need your help on this one. I have the opportunity to buy a 2013 front and rear bumper coming from a coupe.
As i'm looking at retrofitting my 09 with a fresher look. I know the front bumper will fit. Will the rear bumper fit?
As well these bumpers come with parking sensors. Since my car do not have parktronic can i make them work? And what other part will i need?
I would appreciate any kind of input from y'all. Thx
Old Dec 27, 2012 | 01:50 PM
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
When you say "make them work" in reference to the parktronic, do you want to retrofit parktronic? Or do you simply mean "make it look right" on your car?
Because you can do one of three things with your bumper that has parktronic holes even though your car is not equipped with them. Either you can retrofit parktronic (requires someone with the extended knowledge to do so as well as some money), or you can buy the parktronic sensors and install them in the different positions but not hook them up to anything, or you can have the body shop fill all of the holes and then paint the bumper.
Old Dec 27, 2012 | 02:54 PM
abcut973's Avatar
I meant by "make them work", make them actually work as parking sensors. How much are you talking about to retrofit parktronic?
Could it be cheaper with an aftermarket parking aid system?
Old Dec 27, 2012 | 03:49 PM
SheryarYO's Avatar
C63
Are you sure the front bumper fits? I read that there is a slight gap between the bumper and the headlight.
Old Dec 27, 2012 | 05:04 PM
abcut973's Avatar
Looks like it fits according to the picture of that sedan.
https://mbworld.org/forums/c63-amg-w...nt-bumper.html
By the way did you manage to get/install a 2012 bumper?
Attached Thumbnails 2013 C63C Rear bumper to fit 09 C63 sedan?-6mn3h.bmp   2013 C63C Rear bumper to fit 09 C63 sedan?-o3hd2.bmp
Old Dec 27, 2012 | 05:15 PM
BO Knows's Avatar
2010 C63, 2007 X5
Buying aftermarket parking sensors will be easier to install and cost less, but not sure if parking sensor holes on the 2013 fit aftermarket sensors. Check it out:
http://www.midcityengineering.com/re...dance/mid800mm
Old Dec 27, 2012 | 05:35 PM
It would absolutely be cheaper to do an aftermarket system, but then again you may loose that OEM look both outside and the way it functions inside and generally speaking OEM is always better.
I'd contact MBenzNL who does a ton of factory retrofits to find out about price and difficulty in doing this. I'd imagine parts alone would be over $1,000.
Old Dec 27, 2012 | 06:01 PM
VaclavSV's Avatar
2012 C63 AMG Black Series
I dont think it does. Im saying this because the trunks on the coupes are different
Old Dec 28, 2012 | 10:36 PM
abcut973's Avatar
I don't know...from close look pictures coupe and sedan bumpers seem very similar...
Old Feb 23, 2013 | 10:05 PM
abcut973's Avatar
So i have an update for you guys. The answer to my original post is YES.
Just received a rear bumper from a coupe (thanks to Craig) and decided to give it a try. It's not a perfect fit since i'll have to find a way to bolt the diffuser onto the car (underneath) but so far the end result pleases me.
The parking aid sensors fit in with no problem which means i'll be able to retrofit the OEM system (next on my list of mods)
Now that i know it's possible i'll send it for some good painting to match my artic white
Attached Thumbnails 2013 C63C Rear bumper to fit 09 C63 sedan?-02232013253.jpg   2013 C63C Rear bumper to fit 09 C63 sedan?-02232013254.jpg   2013 C63C Rear bumper to fit 09 C63 sedan?-02232013255.jpg
Old Feb 23, 2013 | 11:13 PM
Don't you feel like there's too much lettering on your trunk? Something I'd suggest and still be able to show off C63, AMG, and Renntech is by replacing the 63 on the left wide with a 6.3AMG fender badge. Then you can remove AMG on the right and replace it with Renntech.
Someone did something similar on their S63 and I thought it looked pretty cool:
But if you're happy with the way it is now, just ignore everything I've said!
Old Feb 23, 2013 | 11:23 PM
caddison's Avatar
2010 C63 w/ P30
If the only fitment issue you're seeing is with the diffuser, it seems like the perfect excuse to go with an aftermarket one.
Old Feb 24, 2013 | 02:00 AM
abcut973's Avatar
Thanks for the suggestion but i'm not a big fan. The car came with all those lettering so i guess i got used to it. The only mod i did was to plastidip and that is why you feel it's too much. Black on white effect probably. I might just remove the Renntech badge later. I'm just lazy right now
Old Feb 24, 2013 | 02:05 AM
abcut973's Avatar
For sure CF diffuser will follow ... it never stops....
Old Feb 24, 2013 | 03:50 AM
Cool bro. It was just a suggestion and certainly everyone has their own taste and I can appreciate that.
No, it wasn't the black (which I think looks really nice on your car). It's just too busy for me!
As someone else mentioned with the diffuser, get a CF one! The question is, are the coupe and sedan diffusers the same when going aftermarket?
Old Feb 24, 2013 | 10:46 AM
abcut973's Avatar
I was thinking about getting a diffuser from a coupe. But that is a good question.
Old Feb 24, 2013 | 05:10 PM
Fung63's Avatar
my wife bananas! :D
you know, you should source black side skirt and front bumper and have this white top black bottom theme going
bumper looks great and does look like a good fit.
Old Feb 24, 2013 | 06:52 PM
abcut973's Avatar
Well bumper is dark grey and yeah that is what i thought when i first looked at it. I do have the front bumper as well same color and i thought i could create a new style with all bottom dark!lol!
But my common sense came back so it won't happen
Old Feb 24, 2013 | 06:54 PM
Fung63's Avatar
my wife bananas! :D
too bad... cause if you do that. stick a set of lights on the roof and see how much traffic move to the side when you are near
Old Feb 24, 2013 | 09:35 PM
rpenfuyf's Avatar
bmw
Old Mar 4, 2013 | 03:59 PM
abcut973's Avatar
2012 coupe front bumper
There have been lots of questioning about whether or not a facelift front bumper will fit a pre-facelift sedan. I did the experience this past week end and all i can say is yes with a few modification. It's not a direct fit since you have to find some space for the DRLs, probably cut into the polystirene as the one that came with the bumper was larger than my original one. There is as well a gap at the bottom of each headlights.
Overall it's possible so I guess with the help of a body shop you could get rid of these discrepencies. I still need to figure out a way to wire the DRLs as i don't want to use them as fog lights. Anyone has a facelift wiring diagram that could help understand how it works? Or maybe it's just software?
Attached Thumbnails 2013 C63C Rear bumper to fit 09 C63 sedan?-03032013267.jpg   2013 C63C Rear bumper to fit 09 C63 sedan?-03032013268.jpg   2013 C63C Rear bumper to fit 09 C63 sedan?-03032013270.jpg   2013 C63C Rear bumper to fit 09 C63 sedan?-03032013275.jpg   2013 C63C Rear bumper to fit 09 C63 sedan?-03032013276.jpg
Old Mar 4, 2013 | 04:04 PM
whoadude's Avatar
CLK63BS, 991 C2S, F86 X6M
Looks good, are you going to do a headlight swap as well?
Old Mar 4, 2013 | 04:13 PM
abcut973's Avatar
Not for now. But will think about it
Old Mar 6, 2013 | 07:38 AM
BrettC63's Avatar
C63
Looks amazing. I'm a rookie on all of this but why not just get the face lift/newer headlights since you already put the front bumper on. Couldn't that solve the space/gap? They'd also look amazing. I'm looking into them for my 09' but seems I may have to go aftermarket with the Spyder ones.
Old Mar 6, 2013 | 05:47 PM
abcut973's Avatar
For sure facelift headlights will fill the gap but that means new hood as well and probably set them up with STAR diagnostic
