Stock OEM MB Carbon Ceramic Brake Conversion
Please leave the wheels the original color. i think they are fantastic and make an awesome contrast with the color of your car. also with that wheels your car is unbelievable sporty and also elegant!!
congratulation for the work!!!!!!
2014 Audi RS7
Okay - the rear carbon ceramic rotors don't even come close to fitting. Apparently the "E" series parking brake assembly is MUCH larger and the "C" wheel hub doesn't extend out far enough. One last effort by purchasing the "E" wheel assembly to see if its interchangeable. Long shot but worth a shot at this point.
2014 Audi RS7
Hopefully the brake work is the last part so we can get back to road racing soon!!
For those that care:
Some pics of the difference between the Evo 2-piece(stock size) rear and CC rear rotor.
No wonder you couldnt find any wheels to fit. Those rotors stick out quite a bit further than stock.
I would say you have to run the BS conversion or fender flares just to use these.
A fender flare and wheel spacer would probably work as well.
#33
2014 Audi RS7
MERRY CHRISTMAS to me!
#37
I love the fact that You're not taking shortcuts with this project - from 100% drag monster to 100% road racing killer.
You must really love this car
#38
2014 Audi RS7
Thank you!! Quite the compliment coming from you.
I might NOT be done drag racing yet.
These rotors are much lighter all the way around. The larger rears only weigh 13#, sweet!!
#39
How are you going to widen the rear one-piece wheels? To not upset the offest, wouldn't you need to extend it outwards from the face and essentially make it a "deep dish" wheel? Or do you cut the barrel in half, weld in a new section, and use a spacer to accomdate?
#41
2008 G55, 2012 C63 BS
Keep paving the way. Good job.
Also which track you go to road race?
Looking forward to take my car to the track
Thank you
JV
#43
#44
#46
C63 w/p30; MHP ECU tune+header+mids+CF air intake duct+Akrapovic+wide body kit+ Vorsteiner VS110
#47
Very nice conversion keith. Looks great with the BS wheels. I would leave them the stock color imo. Let me know if you need help on OEM parts I am sure I can get a better deal for you than MHP. Unless they are doing all the work, then I would understand getting them from them.
Also I believe Keith said he could not go larger on the wheels because of his drag radials will not fit and they do not make a bigger size.
#48
I have to ask, as someone who admires your persistence but is curious just how mad you really are...do you really buy OEM parts just to test, and when they don't work you just eat the cost? Or do you have something worked out with a dealer where you can test fit these parts and return if they don't work? Off topic, but I have wondered as I see your threads trying all of this stuff out!!
#49
2014 Audi RS7
Speaking of that I got the "E" wheel carrier today and it looks like its going to be a direct replacement as long as the "E" and "C" axles are the same length. If not I may have to change the axles to the "E" which I understand are larger anyway so that would be a nice upgrade for me. I'll keep you updated as we make progress.
