Cat question..
I had to scratch my itch so I removed the rear resonator fabricated by Sebring and put in ones fabbed by Mille Miglia. The 1 foot long Sebring resonator has two distinct tubes inside with a small hole in each pipe towards the back of them connecting the two chambers, basically a cross pipe. There is also a small area of perforation inside each chamber but 60% of the length of each chamber is smooth. The new ones I had installed are not connected and have more perforations. The net effect of this is a slight increase in volume, slightly deeper note, no drone and a bit more of the warbling/throatiness on overrun & downshifting that other Black Series owners will be familiar with.
All in all it's toughened the sound up a notch further but had less of an overall effect than removing the secondary cats did. That particular step had a great impact on sound, yielding a deeper note and more crackle & pop.
I have been thinking about it all afternoon on bondi beach and I think electric cutouts might be the next step...
Was it dramatically louder with no resonators, surely there must have been more drone?? Maybe I just chop out res altogether and just run primary cats??
Or go cutouts to control volume better, my neighbours freaking hate me as it is...
Go with the resonators first, then the secondaries if thats not enough for ya, thats if you dont mind chopping off your exhaust.
I'm curious because my c63 is currently in the shop for a quaife LSD and secondary cat delete we are going to be chopping off 2nd cats and replacing with 2 12inch straight pipe resonated bullets. Hopefully it sounds good
