Preferred Tires? Any input appreciated
Was thinking on 265/35/18 or 275/30/18 in the rear 245/35/18 or 245/40/18 in the front.
I notices some prior posting mentioning they had 275 in the rear. What are you driving in the front?
looks like i'll have to weed through this -
http://www.tirerack.com/images/pdf/warranty/MI1212.pdf
I've been through this personally. I'll tell you my experience with the PSS warranty on my C63.
Got 2 rear PSS in 275/35/18 from Americas Tire Co. Tires were bald by 14,000 miles. ATC prorated the warranty for me, which ended up being around $150 towards a new set of tires. Got 2 more from ATC at ~$150 discount, clock has been reset for another 15,000 miles.
Still worth it since the tires EVEN lasted 14,000 miles instead of 5,000 miles like the OE pirelli's.
i gotta figure out what to do.
Josh
great tire for DD and spirited driving and not bad on the track (but, like gthal says, if the car is exclusive track/fun car, there are better options). I think a good soft compound tire would be wasted if you use the car for DD
for my daily driving, occasional trips to the 1/4, rainy days... best bang for buck for me has been my nexens... practically no noise, works great in the rain, and works better in the dry... gripwise you can't compare to pss but from the kind of driving i do on the street, the nexens are perfect... and they last even through multiple trips to the track... and once i get a set of wheels for a drag set up, the nexens will last even longer... my best 60' time on street tires came from using the nexens...
to each their own... good luck with your choices...
