C63 AMG (W204) 2008 - 2015
Whats the range of VINs that are affected by the M156 head issues?
Old Dec 13, 2019 | 06:16 AM
  #51
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Originally Posted by Jayflight
can you check if my car is in the affected with the old head bolts ? VINWDDGF77XX9F220769
All 2010 and older, and some early 2011s are affected.
Old Aug 25, 2020 | 06:22 AM
  #52
cherokee94nz's Avatar
2006 C55
I am looking at a 2007 built E63 the owner has told me this engine is not affected by the head bolt issue. Can you please look up this engine number. ​​​​​​​
156983 60 020513
​​​​​​​Thanks Alan
Old Aug 25, 2020 | 08:07 AM
  #53
Valvestud's Avatar
156983 60 020513
​​​​​​​Thanks Alan
all 2010 and older are affected.
Old Oct 1, 2020 | 02:34 AM
  #54
redonettii's Avatar
C63S
Thank you. Could you check WDD2040771F636959?
Old Oct 1, 2020 | 05:10 AM
  #55
Valvestud's Avatar
not affected.
Old Oct 4, 2020 | 09:23 AM
  #56
redonettii's Avatar
C63S
not affected.
Thank you, that was very helpful. If you don't mind, could you run another VIN for me to check the headbolt issue?
It is:
WDD2040771F639764
Also, if possible, could you check this VIN, to verify whether it has the P31 Performance Package and/or LSD?
WDDGJ7HB1DF961130
Thanks so much Valvestud.
Old Oct 4, 2020 | 09:49 AM
  #57
Valvestud's Avatar
It is:
WDD2040771F639764
WDDGJ7HB1DF961130
Neither car has the old headbolts. The 130 has the performance package, but no LSD
Old Oct 26, 2020 | 05:58 PM
  #58
MrLiou168's Avatar
2010 C63 AMG
Any way to check if a replacement has ever been done? WDDGF7HB6AF388934WDDGF7HB6AF388WDDGF7HB6AF388934934WDDGF7HB6AF38893 4
Old Oct 26, 2020 | 06:27 PM
  #59
Valvestud's Avatar
Not without tearing into the engine, or checking with dealer to see if it was done by MB. You should assume it was not done.
Old Nov 12, 2020 | 11:00 PM
  #60
Aussie E63's Avatar
2007 E63
How about WDD2040772A665799? It is from a late Nov 2011 C63, with black rocker covers.
Pretty sure it is safe given year, but would like to be certain.
Old Nov 12, 2020 | 11:03 PM
  #61
Valvestud's Avatar
not affected.
Old Nov 14, 2020 | 07:16 PM
  #62
Aussie E63's Avatar
2007 E63
Thanks Joe! Much appreciated
Old Dec 6, 2020 | 12:09 PM
  #63
Wiqar Khan's Avatar
E63 - 01.04.2010
not affected.
Hi. I'm new into the group. Recently bought registered April 2010 E63., WDD2120771A107967.
it has done 220k km, no coolant issue so far. Only cylinder bank 1-2 running "lean".
.is this one of the affect engines?
Old Dec 6, 2020 | 12:27 PM
  #64
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
All 2010’s are affected. https://mbworld.org/forums/c63-amg-w...rly-2011s.html
Old Dec 14, 2020 | 10:31 PM
  #65
jdoug's Avatar
09 CLS 63 AMG
Hi I just found about the issue and Im obviously effected since mine is a 2009. It has 70 K miles and is not showing issues yet with the coolant or error signs. from what ive read not all of these will eventually become an issue. Is it something that I can just wait and see if it becomes a problem and hope I luck out? since 4 K is not even an option anytime soon. Or if it developes the coolant leaking issue before being repaired does it lead to even more damage and more expenses? I really dont want to part with this car as Ive had it 5 years and its been very reliable up to this point. Thanks so much for any advice!
Old Jan 3, 2021 | 03:22 PM
  #66
AMG-Thang's Avatar
2010 E63 AMG
lastvin.com
I know this is an old thread but I’m still not sure why everyone is asking one “Joe” if their engines are affected. Just go to lastvin.com and enter your vin. If engine is before 60658, you’re probably affected. Easy. Forums are about sharing information, so there you go...
Old Jan 3, 2021 | 03:27 PM
  #67
Valvestud's Avatar
Yes, it is in the affected group. All 2010s and older and some early 2011s are affected.
Old Feb 6, 2022 | 01:01 AM
  #68
tonybaloney's Avatar
E63 AMG
Headbolts
Would it say on the carfax if the headbolts have been replaced? There was a service done that only says “intake manifold gasket(s) replaced”. This was done at 23,000 miles.
Old Feb 6, 2022 | 01:15 AM
  #69
roadtalontsi's Avatar
10 C six trizzle
carfax is trash. I doubt it. Intake gaskets are common.
Old Mar 13, 2022 | 09:52 AM
  #70
cls63hamza's Avatar
cls63 2009
engine m156
can tell me if my engine in affective group 15698360008726
Old Mar 13, 2022 | 11:18 AM
  #71
Valvestud's Avatar
Again, all 2010 and older are affected. You have one of the oldest engines out there.
Old Mar 19, 2022 | 01:45 PM
  #72
cls63hamza's Avatar
cls63 2009
advice
i want to buy cls63 2009 it has some problems like oil leake from timing cover ,keyless entry is not workingand windows key is not working..what’s your advice for me about this car?
Old May 13, 2023 | 03:11 PM
  #73
C43ish's Avatar
C43
I know its a old thread but can someone check this VIN: WDD2040 771F57 3950
Old May 13, 2023 | 04:24 PM
  #74
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Old May 13, 2023 | 04:56 PM
  #75
Valvestud's Avatar
Originally Posted by Jasonoff
Beyond the affected group.
Regards,
Joe
