C63 AMG (W204) 2008 - 2015
18x8.5/9.5 SL63 style wheels 45mm $599 *NEW* from PowerWheels Pro
Old May 14, 2013 | 06:20 PM
powerwheelspro's Avatar
Former Vendor of MBWorld
E320
One set of 4 18x8.5/9.5 SL63 style wheels PWP part number 818
WHEEL SPECIFICATIONS
Additional sizes: 17x8 42mm ($429) and 19x8.5 45mm ($649)
Offset: 45mm
Weight: ~23lbs
Hub size: 66.6mm
Bolt Pattern: 5x112
Finish: Gun Machined Face
Shipping: $85
Price: $599
WARRANTY
Our wheels are made at an OEM factory so we are proud to offer the following:
2 Years Finish Warranty: Many replica wheels finish can be sub par and the finish can crack or peel off. Since our wheels come out of an OEM process, the paint and clear coat thickness is similar to OEM standards. Obvious exclusion is curbing, denting or any other misuse that can damage or etch the finish such as use of strong chemicals.
Manufacturing Defect Warranty: The wheels are made utilizing the low pressure casting process like OEM wheels do and go through rigorous quality controls including 100% x-ray, leak and balancing tests. They are guarantied to fit on your car without vibrating or pulling.
Fitment Warranty: You don't have to know the technical specifications of the wheels your car takes, you can lean on our experience.
If we get it wrong, we will support you as much as we can, or we will take full responsibility and give you a refund.
The wheels are in stock and we can also quote wheel and tire packages.
We do not make money on tires or on shipping, it is just a service we offer to our customers, we recognize not everyone has the time to drop off wheels and tires at their local tire store and waste half a day to get them mounted and balanced.
We will mount and balance them for you and take on the risk of getting it right. We have had many customers that called us after getting their wheels mounted telling us that the tire shop scratched them and asked for replacements. So we focused on putting the synergies in place that allows us to offer that service.
You can always call us at 248 686 2035 if you have any questions.
PURCHASING
You are welcome to purchase the wheels from our website at www.powerwheelspro.com or you can call your order in at 248 686 2035 or we can send you a paypal invoice.
Thanks for looking!
Old May 14, 2013 | 06:44 PM
gthal's Avatar
2012 C63 coupe
Bought my winter wheels and tires from these guys and was very impressed by the service!!
Old May 14, 2013 | 11:05 PM
sickfox's Avatar
SI
I like it! Will this fit a C63BS? Can someone photoshop please?
Thanks in advance.
Old May 15, 2013 | 09:05 AM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
I would not drop those on a BS.... these are probably your standard cast alluminum wheels at that price.. Maybe for winter tires.....
Old May 15, 2013 | 09:42 AM
E320
Hi gthal,
Thank you so much for the vote of confidence! Very much appreciated
sickfox,
We recently shipped a set of the 823s, similar to these to another member here for his Black series as his track wheels... He went for the 35mm offset though cause it different than the C63... We do have these in 35mm offset in case you were going to ask
If they are good for track they are good for the road, right?
Old May 15, 2013 | 04:16 PM
Ekort's Avatar
Veteran: Navy
C63
Nice wheels!!!
Old May 15, 2013 | 04:41 PM
E320
Thank you Ekort
Old May 16, 2013 | 12:06 AM
htoudiee's Avatar
M3, S4, C63
Any pictures on a C63?
Old May 16, 2013 | 01:22 AM
E320
Hi htoudiee
Not on a C63 but on a regular W204. These are just 18x8.5 all around with a slight drop.
The gun metal inserts not only look great but they hide a lot of brake dust.
Old May 16, 2013 | 02:23 AM
htoudiee's Avatar
M3, S4, C63
Do you offer them wider for the rears?
Old May 16, 2013 | 10:10 AM
E320
Yes we have them in 18x8.5 and 18x9.5 which is what we would recommend for your C63.
Thank you,
