C63 AMG (W204) 2008 - 2015
How to Remove Rear Door Handle
Old Jun 27, 2013 | 08:59 PM
SheryarYO's Avatar
C63
Hey guys. I'm having trouble getting to the T-20 screw in the rear door to take the door handle off. I took the front one off since it's not too far in and therefore easy to see, but there's a lot more room for error in the back and I can't see the screw inside even when trying to flash a light in there...any help?
Old Jun 27, 2013 | 11:40 PM
blackc230benzo's Avatar
2010 C63, 2003 C230 coupe
same as front but you will may need a longer screwdriver or t20 bit.
Old Jun 28, 2013 | 12:43 AM
SheryarYO's Avatar
C63
guess i'll just have to try and get lucky tomorrow.
i'm also having trouble putting the handle of the front door back on. I'm pretty sure i'm supposed to put the actual handle in first and then the smaller piece, but I just can't get it to work.
Old Jun 28, 2013 | 12:51 AM
SheryarYO's Avatar
C63
aaaand in case anyone cares, here's a couple quick pics of the door i wrapped today. i also wrapped the chrome trim in gloss black.
hopefully i can figure out how to get the handle back on and knock out the rear door tomorrow as well.
Old Jun 28, 2013 | 01:52 AM
LAMB09's Avatar
2011 C63 AMG
You need a 6in t20 to reach it. I bought a bit off amazon for like 7 dollars. Worked great. Good luck, what color are you wrapping your car?
Old Jun 28, 2013 | 12:47 PM
SheryarYO's Avatar
C63
matte gray. first time ever trying it and I've already messed up a couple times on the hood, but the door worked out great...other than not being able to get the handle back on yet.
Old Jul 2, 2013 | 06:25 PM
SheryarYO's Avatar
C63
got the fender done today.
still need help figuring out how to take the rear door handles off. I've got a 6 inch torx screwdriver, but there's just so much room for error. would it be easier if I just took the whole inside door panel off?
Old Mar 3, 2019 | 01:52 PM
wfooshee's Avatar
2007 Jaguar XJ8L, 1999 Miata, 2003 Yamaha FJR1300
That bolt is only accessible through the hole. Removal of the interior panel is not only unnecessary, it gains you nothing on the rear handle.
Dang. Just saw how old this thread is. Found it in a search, not by browsing. Off to lunch, now, bye.
Old Apr 15, 2021 | 10:55 PM
Jordan Fleury's Avatar
2013 Mercedes Benz C300 W204
2013 Mercedes Benz C300 4matic Luxury i dont know if you need all of this but mine for some reason was a t15 but you need a long t15
Old Apr 16, 2021 | 12:00 AM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Totally useless
