C63 AMG (W204) 2008 - 2015
What gear is 1:1 on these car
Old Jul 9, 2013 | 10:59 PM
skaarlaj's Avatar
ford svt's, and C63!!!
Just curious as I might get a chance do do a dyno pull here within the week.
CarHopper's Avatar
E63S | X5
Should be 4th
Old Jul 9, 2013 | 11:03 PM
skaarlaj's Avatar
Thanks, then the rear gear must be pretty steep with three od gears in the trans?
Old Jul 9, 2013 | 11:05 PM
CarHopper's Avatar
E63S | X5
I would imagine so, yes. If I were you I would still check back in here for an expert to chime in but I am rather sure I've seen 4th gear is the 1:1 in another post a couple months back
Old Jul 9, 2013 | 11:06 PM
Even Money's Avatar
'15 VW GTI
forum gouge...
5th is 1:1, however, I would dyno in 4th, more realistic speed, plus you won't be winding it out to 175+ and bumping into the limiter if you're stock
Old Jul 9, 2013 | 11:19 PM
CarHopper's Avatar
E63S | X5
^ Ah ok that was it. Thanks for chiming in but it was another dyno post somewhere in the depths of the forum saying 4th was the gear to dyno in
Old Jul 9, 2013 | 11:41 PM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
I had read about some folks doing it in 5th but the guys at 034 Motorsport said 4th would be better.
Old Jul 10, 2013 | 08:13 AM
skaarlaj's Avatar
Thanks guys.
Old Jul 10, 2013 | 11:10 PM
msheredy's Avatar
MB
Little trick my dad taught me was to watch the speedo and tach needle. When they raise at the same rate note the gear and that's your 1:1.
Old Jul 11, 2013 | 09:59 AM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
I thought 6th was 1:1
Old Jul 11, 2013 | 07:57 PM
Mort's Avatar
Transmission gearing: 4.38/2.86/1.92/1.37/1.00/0.82/0.73/R3.42
Final drive ratio: 3.06
Old Jul 13, 2013 | 12:50 AM
skaarlaj's Avatar
Thank you Mort, good info.
