C63 AMG (W204) 2008 - 2015
engine knock? when cold
Old 08-31-2013, 11:19 AM
thetrance's Avatar
12 c63
Hello,
difficult to describe this but i think its an engine knock when the car is not at normal operating temperatures. When reving to between 3-4 k while driving, i feel a weird pulsating feeling throughout the car. it goes away when its warm. it happenes for the first 5 minutes of driving, engine NOT completely cold
I am using higher quality 94octane gas, if that makes a difference
any suggestions?
Old 08-31-2013, 11:56 AM
JGreen76's Avatar
C43
Year, mileage, mods?
Old 08-31-2013, 11:57 AM
thetrance's Avatar
12 c63
2012 with 6000KM no mods other than greenfilter and charcoal filter removed
Old 08-31-2013, 12:11 PM
Merc63's Avatar
C63 AMG
Usually knocking is bearings. Would be metal filings in you oil.
Old 08-31-2013, 12:12 PM
thetrance's Avatar
12 c63
would a sticky lifter cause similar symptoms?
Old 08-31-2013, 01:31 PM
CarHopper's Avatar
E63S | X5
I would guess the pulsating is a mental thing because of the noise you first hear which I would also guess is a lifter.
Did the car sit for a bit between drives when you heard it? One time thing or occurs every time?
Old 08-31-2013, 05:02 PM
thetrance's Avatar
12 c63
happens once in a while, i drive it daily so not sitting for a long time,...
Old 09-02-2013, 12:11 PM
C63newdude's Avatar
C63 AMG
I use to have that noise on my car as well, it is typically the valvetrain and lifters making the noise when the oil is cold. Typically the noise goes away on its own.
Old 09-02-2013, 12:36 PM
thetrance's Avatar
12 c63
yeah but when im driving it feels like a misfire. ill take it in to see if they can read any codes. feels like either bad spark plugs or transmission problem or bad gas
Old 09-02-2013, 05:25 PM
CarHopper's Avatar
E63S | X5
^ Could be any combination. A misfire code would trigger a CEL though. Probably not a tranny issue. Bad gas, maybe. Spark plugs at 6000km, doubtful.
Quick Reply: engine knock? when cold
