C63 AMG (W204) 2008 - 2015
Stock 507 Tires
Old 09-27-2014, 09:45 PM
WESLEY KAY's Avatar
2014 C63 AMG 507
Originally Posted by DuaneC63
Really not going to make much difference in performance (might even make it worse). A 275 is taller, lowering your rear end ratio. They weigh more increasing both rotational and un-sprung mass. Assuming you get 10mm more of tread width (which you may or may not as the width number is the section width not the tread width) it's not going to make that much of a difference in handling or hooking up. Admittedly the 265 are too narrow for the drive train, but unless you punch out the rear wells and shove some 315 under there, hook up is always going to be a problem. You'll get more result in handling by upgrading to more robust coil overs. Did all the 507 come with LSD? If not, put a Quafe in. It like doubling your tread width.
Why would the 275s be taller? I would still be going with 30s, not 35s. And this would be coming from a 255/30 setup, so possibly 20mm difference. I believe the rears are 30. I forget. I figured anything would be better than the 255s.
The LSD was an option only on the 507. Mine did come with one. It helps tremendously.
Old 09-27-2014, 10:37 PM
cacmf's Avatar
2015 C63 507
Similar thought here. I was debating to go up to 265 or 275. 275 will up the rear end and change the dynamic unless going with a aspect ratio of 25, which mostly will be a poor fit for Jersey roads that are full of landmines. With 265, not sure how much difference it'll make. The stock yoko on the my 507 seems decent enough, though VERY LOUD.
Old 09-27-2014, 10:42 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
Originally Posted by WESLEY KAY
Why would the 275s be taller? I would still be going with 30s, not 35s. And this would be coming from a 255/30 setup, so possibly 20mm difference. I believe the rears are 30. I forget. I figured anything would be better than the 255s. The LSD was an option only on the 507. Mine did come with one. It helps tremendously.
the 30 is a % of the width, so 30% of 275 is more than 30% of 265, = taller.
Old 09-27-2014, 10:44 PM
cacmf's Avatar
2015 C63 507
Yes, 507 comes with 255/30. 275/30 will up the side wall by about 1/4 inch.
Old 09-28-2014, 03:28 AM
rediesel's Avatar
2006 E320 CDI 2014 C63 507 Coupe 2012 E550 4M 2016 E63s Wagon
I put a set of OEM 255 when my rears wore out. When the next set goes I'm getting 275 rear and 245 front in PSS.
Old 09-28-2014, 07:20 AM
WESLEY KAY's Avatar
2014 C63 AMG 507
Ah that explains it, thanks much!
Old 09-28-2014, 11:00 AM
  #32
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
Soooo....507 guys and gals. I am debating the 265 vs 275 option in the rear as well. Any objections against the 275s in hard cornering on the stock 507 wheels? I will be going with the Michelin PSSs. I am thinking 265 to be safe because I do hard cornering for shizzle!! Anyone?
Yes. During hard cornering, a 275-size tire mounted on a 9" wide rim will have way too much sidewall flex. Go with a 255 or 265. You won't notice the difference in grip, but you will definitely notice the back of the car squirming around with a 275 on the OEM rims.
Old 09-28-2014, 11:07 AM
  #33
WESLEY KAY's Avatar
2014 C63 AMG 507
Thanks! I am going to go with the 265s.
Quick Reply: Stock 507 Tires
