C63 AMG (W204) 2008 - 2015
Vacuum line location?
Old Oct 7, 2013 | 06:11 PM
anthonymckay's Avatar
2013 C63 AMG
Installing the valvetronic hardware/wiring for my new exhaust. Could anyone possibly post a picture of a good vacuum line to tap into? Not sure what I'm looking for exactly. And as for tapping into this, can I just cut it, and insert a t-valve in between the hoses?
Even better would be anyone with an AgencyPower exhaust that could post some clear photos of where/how the vacuum line and such were installed. Would appreciate any help on this. Thanks!
Old Oct 8, 2013 | 02:50 PM
2013 C63 AMG
Again, no one has ANY info that might be helpful? I'm kind of shocked that the last two posts I've made regarding this exhaust install have gone unanswered. I know other members here have agency power exhausts. I know SOMEONE has to know where a vacuum line is on our cars
Old Oct 8, 2013 | 08:17 PM
VividRacing's Avatar
Former Vendor of MBWorld
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
Did you get the email I sent you? The pictures should show where the vacuum line we use is located
Old Oct 8, 2013 | 08:32 PM
2013 C63 AMG
I did, but those pictures don't really show very well exactly what hose it's connected to, just where the vacuum line routes through the cars.
Old Oct 8, 2013 | 08:52 PM
True, that doesn't help much. My tech is telling me he t'd into the line for the Evap system that is in that location.
Old Oct 8, 2013 | 09:57 PM
2013 C63 AMG
When you're talking to a non-mechanic that information still doesn't help much, haha. I was able to figure out which one to tap into though. Taking plenty of pics right now to create an install guide
Old Oct 8, 2013 | 11:42 PM
roadtalontsi's Avatar
10 C six trizzle
at the bottom right of the red circle, do you see the solenoid valve? this is the purge valve. tap into it between the motor and the valve (you should see an arrow on the valve that points to the engine and says "mot" or "motor". This is the side you want. If you t- into the other side it'll be on the fuel tank side which will probably cause all sorts of b.s. purge leak evap codes and have your exhaust not working correctly.
Old Oct 9, 2013 | 12:05 AM
2013 C63 AMG
Phew, I tapped into the right spot then, haha. Thanks for this!
Old Oct 9, 2013 | 01:04 PM
Sweet! Everything working well Anthony?
Old Oct 10, 2013 | 12:03 AM
2013 C63 AMG
So far so good! Finished up running all the hoses/wires this evening. Everything seems to be working perfectly
Old Oct 10, 2013 | 02:37 PM
Great to hear!
Let me know if you have any questions
Old Sep 23, 2020 | 05:47 PM
luvboost's Avatar
c63 AMG
Bringing this back from the dead. There isn't much content on this subject. Any chance Vivid could post that picture here? Not much in the way of how to install this exhaust and AP's install doc is without pictures.
Old Sep 26, 2020 | 12:36 AM
10 C six trizzle
what do you want a picture of? vacuum source for an m156?
Old Sep 26, 2020 | 09:24 AM
luvboost's Avatar
c63 AMG
na. Already figured it out. Used the source connected to the intake.
Old Mar 15, 2022 | 05:17 PM
dylanbrown18's Avatar
C43 amg
Where is the evap line
can you post pictures? Trying to find the evap line myself! Thanks
