C63 AMG (W204) 2008 - 2015
track tires
Old Oct 17, 2013 | 03:12 PM
kgmuse's Avatar
12 C63 : 19 GLC 43
track tires
does anyone have suggestions on what brand to get? I'm going to be running 8.5x18 in the front and 9.5x18 in the rear. I've ran Bridgestone Pole Positions in the past to dual as summer tires. not opposed to something similar. thanks!
Old Oct 17, 2013 | 03:27 PM
mdgrwl's Avatar
C63 AMG
Nitto NT01
or
Toyo R888
Old Oct 17, 2013 | 03:41 PM
C63-AMG's Avatar
2009 C63 2016 AMG GT S
I was just thinking of the same thing. What rims/tires for drag racing could be used.
Found this thread for drag race rims/tires.
https://mbworld.org/forums/c63-amg-w...ag-racing.html
Old Oct 17, 2013 | 03:45 PM
mdgrwl's Avatar
C63 AMG
Weld Racing makes drag rims for just about every car - used them on my 10 second SRT8.
M&H Racemasters are some of the best drag radials out there. Mickey Thompson are pretty good to but not as soft compound and a little heavier.
Old Oct 17, 2013 | 05:49 PM
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
It depends a lot on what you mean by track tires. Are you road racing or drag racing?
Old Oct 17, 2013 | 05:55 PM
kgmuse's Avatar
12 C63 : 19 GLC 43
road racing for sure. b
Old Oct 17, 2013 | 06:58 PM
C230Kompressed's Avatar
I drive what I drive
road race?
Advan AD08
Toyo R888
Bridgestone Potenzo RE-11
Hankook RS3
Nitto NT-555R
Old Oct 17, 2013 | 10:58 PM
b16's Avatar
b16
2009 C63, 2000 ML 430, 1994 Del Sol Vtec
Road race,
If you want a tire for track only get some Hoosiers R6's or Hankook Z214 C51's.
Old Oct 18, 2013 | 08:42 AM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
Originally Posted by C230Kompressed
road race?
Advan AD08
Toyo R888
Hankook RS3
Nitto NT-555R
Of all the tires you listed above, only the R888s are R-comps for track use. AFAIK the Nitto Rs are for drag racing only, and the rest are all street tires.
The Toyo R888s are decent track tires. Got my first set for the C63 a month ago and liked them. Pretty consistent, fairly progressive for an R compound and withstand repeated heat cycles well. Have corded many sets of Toyo RA1s in the past and are by far the brand I've purchased the most, having used Kumho Victoracers, Yokohama A048 and Hoosier R6. The Hoosiers are the stickiest of the bunch but NOT tires you can use in the wet or drive on to and from the track.
Old Oct 18, 2013 | 09:24 AM
kgmuse's Avatar
12 C63 : 19 GLC 43
loving the advice. I theoretically would get something I can I drive to the track and back to home with. it's a good 35min trip the nearest track.
Old Oct 18, 2013 | 10:25 AM
Merc63's Avatar
C63 AMG
Re11
Old Oct 18, 2013 | 10:30 AM
Diabolis's Avatar
If you're going to be using your OEM 18" wheels for the track, the Michelin Pilot Sport Cup come in a 235/40 and 265/35 sizes and have an XL load rating. Always wanted to try a set but never have.
The Toyo R888s come in the OEM 18" 235/40 and 255/35 sizes (also XL load).
Old Oct 18, 2013 | 10:52 AM
Diabolis's Avatar
Maybe I am missing something, but could someone tell me how the Bridgestone RE-11s are any different from, say, Pirelli P Zeros? I have had them on the P-car but they seemed to be just a decent street tire, nothing more. An R-comp is easily worth seven seconds a lap around Mosport on my track car. Just curious.
Old Oct 19, 2013 | 07:47 PM
kgmuse's Avatar
12 C63 : 19 GLC 43
Originally Posted by Diabolis
If you're going to be using your OEM 18" wheels for the track, the Michelin Pilot Sport Cup come in a 235/40 and 265/35 sizes and have an XL load rating. Always wanted to try a set but never have. The Toyo R888s come in the OEM 18" 235/40 and 255/35 sizes (also XL load).
I'm going to be using rep wheels that are lighter. I love michelins and run pilot sport a/s plus right now for daily. i love in Colorado so I def need something that can adapt to a quick change in weather since the nearest track to denver is a bit outside the city.
Old Oct 19, 2013 | 08:49 PM
Velociabstract's Avatar
SRT-6
I like Kumho Ecsta XS and Hankook RS-3 in the street car/track use category. Hankook Z-214 are as good as Hoosiers when new but after a few heat cycles they fall of to RS-3's times. I don't like the Pilot Sport Cups much for the track. They were sticky but unpredictable. The 360º spin convinced me to start looking elsewhere. I'm on Hoosiers now but only one event. I don't have enough experience on them to opine.
Les
Les
Old Oct 19, 2013 | 09:17 PM
turbo8765's Avatar
C63
The RE-11's are quite fast. I can run as fast on the RE11 as the R888, for a lap or two. They're forgiving and wear well. They don't handle heat as well as the RS3. The RE11's do have a soft sidewall for a UHP.
You're experience is a key consideration. If you you're a novice to intermediate I would run a UHP street.
Dunlop SSII, RE11a, RS3, or Exsta XS. Personally I prefer the RE11.
If you're more experienced and have to drive to the track I'd go with the NT01. Personally I think it's the gold standard entry level R comp. Decent in the wet and they're fast till they cord. It's amazing but they don't heat cycle out at all.
I think the R6 is a terrible idea unless your experienced and your car is seriously modded. I wouldn't consider driving them 30 min to the track either. They heat cycle out, are terrible in the rain, and wouldn't work well with stock alignment and spring rates.
Old Oct 19, 2013 | 09:29 PM
esses's Avatar
2013 P31 C63, 2014 Bluetec ML, 2004 GT3
This is the first mention of the fact that r comps on street alignment, spring rates, and brakes would likely overwhelm the car.
Has anyone with extensive experience tried running r comps on a stock setup? What was the result?
Old Oct 19, 2013 | 09:36 PM
turbo8765's Avatar
C63
I'm not saying it would overwhelm the car so much as it would be a waste of an expensive tire. R6's like a lot of camber, for example. And again, driver experience level is important to consider too. When I first started I drove on hard cheap tires that lasted a long time.
Keep in mind "r comps" covers everything from an NT01 to an A6 to a full slick. I think the C63 would be fantastic on NT01s or R888s.
Old Oct 19, 2013 | 09:50 PM
roadtalontsi's Avatar
10 C six trizzle
if you've never been to the track before, i agree theres no point in buying special tires. Just use what ever the car has. When you get some experience and feel the tires are holding you back then id go with the r888 and drive to and from with those tires. Its a pain in the *** to be swapping tires and all that unless you've got a trailer or really good friend. Not to mention driving the car on the track will wear you out so much. you really wont want to work on the car too. The r888s worked great on my 500whp supra and lasted 4k miles on the street, which is longer than normal street tires would last on the rear. keep in mind the supra goes from 100whp-500whp with in 500rpm so there is normally a ton of wheel spin. keep in mind r-comps to have to get alittle warm to start working. when the tires are cold it's almost like driving on ice. I cant speak for tires specific on the c, havent gotten out to the track yet with it, but i doubt these nt05s are going to be worth a crap.
Old Oct 20, 2013 | 02:52 AM
Diabolis's Avatar
As others have said - if you're a track newbie, I would definitely stay away from R-comp tires until you have a pretty good feeling for the car on street tires. It's not that it would only be a waste of money, it's that R-compound tires generally do not give you nearly as much warning that you're at the limit and are a lot less forgiving once they break away (you have full grip with no tire squeal one second and you're gone the next). Until you get pretty comfortable with car dynamics and you can "feel" what the car is doing (which is likely going to take a couple of seasons), I would stay away from R-comps simply for safety reasons. Once you start to consistently turn good laps, not overcook your brakes and you hit every apex lap after lap - in other words, when the car becomes the limiting factor instead of the driver (you) - that's when you start looking into how you can go even faster.
Old Oct 20, 2013 | 03:04 AM
Diabolis's Avatar
Thanks for the input on the RE-11s - will have to get a set and try them out again. Yes, the C63 on R888s is a pretty amazing ride (at least the LCI chassis - I haven't driven a pre-2012 on a track). It feels like it could easily match an E9x M3 on a fast sweeping track.
Old Oct 20, 2013 | 08:21 AM
turbo8765's Avatar
C63
Agreed... When the sound of constantly squealing street tires becomes so annoying you just can't stand it anymore, you're ready for R comps.
Old Oct 20, 2013 | 09:29 PM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
..... It feels like it could easily match an E9x M3 on a fast sweeping track.[/QUOTE]
Even more so with K-MAC front Camber and Caster adjuster kits and rear Camber and Toe kits. Being able to dial in precise extra plus or minus Camber/Traction for going deeper into the corners!
Old Oct 21, 2013 | 12:47 AM
Diabolis's Avatar
Can you PM me some more info on the kits? Range of adjustment, materials, what's included, etc. Is it just the bushings (all I could find on your website for the W204) or a full camber/caster plate kit like Ground Control for example?
Old Oct 21, 2013 | 05:41 AM
Chargin55's Avatar
2003-E55 2011-C63 2016-C63S
I'm thinking a good tyre for you is a Dunlop Direzza 11. And up size. 245/40/18 and 265/35/18
