Andrew's Log: C63
#78
C63 AMG 2009, ML63 AMG 2007
Yes I know, but I just already paid the Velos wheels…
I cannot afford to buy these wheels too man…..my wife kills me I buy these wheels too.
Because I already have then 4 sets of wheels in my garage...
#80
I agree with Matt, u wanted a kit that looks different from the BS.. Than going different wheels only makes sense.
I also like the Velos wheels, but I'm bias cuz they look like my HRE P40 a bit.
#82
Well u still lost the deal of ur life nonetheless.
(Unless Velos gave u a killer deal)
#83
It was 4k, with shipping $ 4482,….they asked in the beginning $ 5500 without shipping.
I hope I have a good deal...
#87
I don't know the offset, I will ask tomorrow my body shop
#90
I called to my body shop and they could not told me how to measure the offsets
That's really weird…for a professional body shop they should know it
Because I have the same fenders or wide body kit like the original Black Series, the offset should be the same then like a real Black Series.
I don't know what are the standard offset for a real black serie C63, so if this offset is the same then i would be good?
#91
It's not easy to measure the offsets on a car without the right wheels.
But if you have Black Series fenders, then you should do fine with the Velos wheels
When are they coming?
#92
The rear axles in your car are shorter than the Black series axles (E Class axles) so you might need spacers on the rear depending on how flush you want the rear wheels to be with the fenders or in case they rub on the inside.
#96
Yes, u will need the E class rear axle to match the OEM black series offset, or else spacers will be required for flushness.
Bodyshop will not know how to measure offset on custom work. Only a wheel specialist could do the measurement. Search for Craiger, he did the same conversion with the C class axle, he tried to estimate the offset & came pretty close, he ended up using spacers on his Rennen though.
I hope u will lower the car on coilovers after cuz ur car will look like a 4x4 after the kit is installed. Again, look at Craiger pics before & after lowering.
#97
Roswell..
Can you point to the thread of pic before and after with out coil from craig ?
I know we would need spacers but wonder how much ...too much is not good....
He could use H&R spring ? or it has to be coil to look more flush...
#99
Give me a sec, I will look for his built thread.
#100
Here it is, lots of infos & pics of the conversion here:
https://mbworld.org/forums/c63-amg-w...delivered.html
