C63 AMG (W204) 2008 - 2015
HELP! Lowered with alignment problem
Old Oct 2, 2014 | 10:54 PM
  #51
cjoy63's Avatar
08 C63 P30
Hoping someone can take a look at my alignment as my car is pulling to the right too after lowering with H&R's:
Front (L/R):
Camber = -2.0/-1.8
Caster = 10.9/11.1
Toe = 0.18/0.17
Rear (L/R):
Camber = -1.8/-1.6
Toe = 0.46/0.35
Looking at the before and after numbers, the rear did not change a single degree, the front on the other hand did..
Thanks in advance
Old Oct 5, 2014 | 10:11 PM
  #52
roadtalontsi's Avatar
10 C six trizzle
where do you live and are the roads flat or banked for drainage, and if so how banked which way.
Old Oct 6, 2014 | 12:04 PM
  #53
cjoy63's Avatar
08 C63 P30
I live in Northern California. Need to confirm, but I recall hearing roads here bank to the right, not sure how much.
Old Oct 7, 2014 | 12:33 AM
  #54
10 C six trizzle
id pull the left front camber arm in. That'll give you alittle more pull to the left. right now it should only have a light pull to the right. with that move it'll pull about 2x as much to the left.
