C63 AMG (W204) 2008 - 2015
lowering using rear spring top shim?
Old Dec 26, 2013 | 06:05 PM
Ingenieur's Avatar
C63 AMG
has anyone done this?
for my VIN it shows 4 top spring shims
5 mm
9 mm
13 mm
17 mm
iirc the car comes with 13's
if they were swapped for the 5's would that lower the car 8 mm?
I'd like to lower mine but don't want the 20 mm (and the ride and potential alignment issues) the H & R's offer
I'd like to lower the rear a bit, the front seems OK
this might be a good solution
has any one done it?
Old Dec 26, 2013 | 08:04 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
people swap spring pads a lot in the w202 c43, so I'm sure it would yield what you're looking for. some nay sayers were saying not to bother, since the drop is so negligible, though. if you're looking for an 8mm drop, I'd say go for it. of course, you'd have to check to see which pads are on your car already.
Old Dec 26, 2013 | 10:02 PM
roadtalontsi's Avatar
10 C six trizzle
ive actually got a set of 5's and possibly 8's - might be 13's. If you're interested I'll let them go for 15$+shipping. Ill double check the p/n's tomorrow they are like new.
Old Dec 28, 2013 | 10:16 AM
Sincity's Avatar
I'd like an 8mm drop and still retain OEM ride quality. Can anyone else confirm the stock 13mm spring pad all around?
Old Dec 28, 2013 | 02:31 PM
iirc, the pads can vary by car. you'll need to check yours to be sure.
Old Dec 28, 2013 | 11:16 PM
Ingenieur's Avatar
C63 AMG
I don't think the pads in the front have different heights
Old Dec 29, 2013 | 01:20 AM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
I don't recall any pads in the front?
Or are you talking about the bearing/upper mount?
Old Dec 29, 2013 | 09:52 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Only the rear has spring pad, OEM are 13mm.
Dropping the rear only with pads will look weird as our cars sits lower in the rear stock form. I actually had to raise the rear with 17mm pads after installing my H&R springs.
Old Dec 29, 2013 | 07:47 PM
Ingenieur's Avatar
C63 AMG
this is the parts diagram for my car, a 2009
item 8 is the upper pad, 4 is the bearing
it appears to have a pad, but unlike the rear only 1 PN is listed
the rear has 4, each a different thickness
perhaps the front could be shaved down 5 mm or so?
imo not worth the aggrevation of disassembly
the rears would be easy to swap out
some measurments from mine:
floor to fender lip: F 26.0, R 25.8 w/ 3/4 tank of fuel
tire to fender lip gap, measured with a string, level and steel rule:
F 26 mm (1.02"), R 24 mm (0.95")
So both are basically 1" for all intent & purpose, they are the same, I think it's an illusion that the rear is lower, mine actually looks higher, but measures the same.
I don't think the H&R's lower the rear more than the front, but the Eibachs do for many applications, to help transfer some weight rearward
tires OD loaded at curb
F 25"
R 24.85"
makes sense since unloaded OD is F 25.4 and rear 25 per mfg data and the front is lower pressure and carries more weight so would compress a bit more
To get a 'rake' reference I used the seam at the door bottoms from floor to middle of the seam measured at each wheel arch. I've seen lowered cars where this is almost level.
F 10.2", R 11.7"
1.5"/78" or 2% rake
If the rear is lowered 8 mm or 0.3" the rake would be 1.2/78 or 1.5%
I think the 8 mm drop would level the car out a bit and make the wheel/fender gap appear even (although the rear would be 0.7" vs 1" front).
I like the 'look' with a bit of rake and the front gap a bit larger than the rear
Old Jun 29, 2014 | 01:06 AM
C300forlife's Avatar
09 c300
Still have those 5mm ?
