C63 AMG (W204) 2008 - 2015
need help from all the tyre gurus
Old Jan 16, 2014 | 09:35 PM
mr747's Avatar
c63
Charlie do you think with 255 30 19 pss will work??
I really want the PSS tyre im happy to go from 265 to 255 but i want to keep the spacers
Old Jan 16, 2014 | 10:11 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Originally Posted by charliekay
Here is the specs of the 265/35/18 vs 265/30/19.
The tread width of the 265/30/19 is 10in vs 10.1in for the 265/35/19.
Tread width difference of 1/10th of an inch is 2.54mm which could be the difference between rubbing or not.
Remember the profile of the tyre makes a difference.
This is not saying that the 265/30/19 will work 100%, just saying that just because the 265/35/18 doesn't, doesn't mean the 265/30/19 won't.
Size UTQG Max Max. Tread Tire Rim Meas. Sect. Tread
Service Description Load Inflation Depth Weight Width Rim Width Width
Load Range Press. Range Width
265/35ZR18 300 AA A 1609 lbs.* 50 psi* 10/32"* 26 lbs. 9-10.5"* 9.5"* 10.7"* 10.1"*
(97Y)*XL
265/30ZR19 300 AA A 1433 lbs.* 50 psi* 10/32"* 25 lbs. 9-10"* 9.5"* 10.7"* 10"*
(93Y)*XL
You need to account for section width and sidewall height. The tread width can be a factor if it's a lot smaller than the section width which would indicate a much "rounder" transition to the sidewall and "could" account for more fender clearance.
Old Jan 16, 2014 | 10:46 PM
charliekay's Avatar
C63 AMG
255 should work, I haven't tried it myself but I know Matt (olszowa12) ran 255s with spacers without an issue.
Agreed, they are all relative to each other. The section width for both are 10.7" but the 19s has a tread width of 10 vs 10.1.
Without pretending to be an expert on this topic, I would say this means that the 19s would have a more rounded sidewall since the tread width is slightly less but the same section width.
Old Jan 16, 2014 | 11:34 PM
bhamg's Avatar
C63 AMG
I'm not sure why there is all this talk about section width. I'm putting the 275-shod wheels back on in two weeks. When I hit the next unavoidable dip at speed and cut some strips off the tire I'll pull over and photograph it. You'll see the strips are coming off the tread, not the side of the tire. The PSS's are crazy wide in the tread - IMO that is the problem.
Old Jan 17, 2014 | 07:47 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Generally when "tread width" is mentioned, it's the actual contact patch. The tread still wraps around the corner to meet the sidewall. The radius/arch of that transition is a factor for fender clearance. Not to mention rim width is a factor as well since it can slightly change the shape.
Old Jan 17, 2014 | 08:01 AM
Kriston's Avatar
C63 AMG
The T1R's are not a bad tire. Not as good as the PSS's. I have the PSS's on the C63 now, I had the T1R's on my previous car.
The downfall to the T1R's in my opinion is the road noise after some wear. They get horribly loud. Just my experience with them.
Either way, the T1R's are a decent tire, not that far off in terms of price compared to the PSS's. I would probably spring for the 255 wide and run a mild stretch. If memory serves me correct the contact area on the stretched 255's will come close to the 265's.
Kris
has anyone had experience with the toyo t1r tyres???
Are they good??? how do they compare to the PSS
Old Jan 17, 2014 | 09:32 AM
  #32
Mort's Avatar
From all the math I've done I think so as well. I ended up going with RE-11 because the front 245/35-19 AD08R have too low of a load rating. The 275/30-19 RE-11 has the same 10.7" section width.
You have an up angle "down the side" pic of the rear with that setup showing the clearance?
Jason check this thread out it has pics of my car with the current wheels I am running.
https://mbworld.org/forums/c63-amg-w...w-cf-lips.html
Old Jan 17, 2014 | 10:45 AM
  #33
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
