Supercharger s1 vs s2?
https://mbworld.org/forums/c63-amg-w...10-7-pass.html
A factory manifold or even a PLM header is a bottle neck in airflow and this is why the Stage 2 system will not run well with these headers. It will create serious back pressure in the cylinder (pressure creates heat) and will eventually damage engine internals.
A long tube header on the other hand can flow at a much higher rate and therefore allow heat and pressure to evacuate out of the exhaust, allowing us to spin the blower faster and create more power.
In terms of boost, the Stage 2 system with a proper long tube exhaust only makes about 1-2 psi more than our Stage 1 system with stock exhaust, but the increase in airflow is significant and this is where you see big gains in power and torque.
We hope this explains this topic a little more in detail. Thank you.
Weistec Engineering
Weistec Engineering
Weistec Engineering
