C63 AMG (W204) 2008 - 2015
Cannot Keep tires from spinning at any speed
Old 01-20-2014, 09:59 PM
mattc63_Nuke's Avatar
MB 2009 C63 AMG
Hello
I am a new Member, and bought a 2009 C63 AMG, that I have had the ECU updated with the Weistec Tune 1
Since the update this car is a V8 Nuke.
What are the best tires to keep them on the car with manor of control. When I bought it it has Goodyear Eagle F1. With very little throttle the car breaks lose and the rear end is everywhere.
These tire have very wide groves leaving little rubber to contact the road.
If anyone can help, please let me know.
I have ordered a rear wing for the highway where if I step on it, the back end breaks loose.
Mattc63_Nuke
Old 01-20-2014, 10:04 PM
Autosport7's Avatar
C63 AMG
Sub'd
In for best response! Not the worst problem in the world to have, but would love to be able to utilize all ranges of power in the car.
Old 01-20-2014, 10:12 PM
AMG Boost's Avatar
2010 C63 P30
Just got my C63 and I was also curious what people are running for tire.
If I was to go out and buy a summer tire for this car, Id get Pilot Super Sports.
Old 01-20-2014, 10:17 PM
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
I run Pilot Cups on my C BS, great traction for a street tire, however they wear out fast so if you are on a budget you might want to go with something with a higher treadwear rating.
Old 01-20-2014, 10:27 PM
zibby43's Avatar
'20 GLC300 SUV
Easiest solution: Get wider tires. Equip your car with the widest tires available (up front and in the rear) and you'll begin to see your traction increase. Just make sure the tires will fit without any rubbing.
The ContiSportContact 5P and Michelin Pilot Super Sports are both outstanding tires. They're probably two of the best street/daily tires money can buy.
I've also heard good things about the Toyo R888.
On the track, Dunlop is where it's at for this car, IMO.
Old 01-20-2014, 10:32 PM
chrisridebike8's Avatar
'10 C63
Heard good things about PSS. I had 5Ps before and the SO4s I have are much stickier. 265s. When it's 70+ outside I can launch from a standstill and almost not get any wheelspin even with the EC v4 tune.
Old 01-20-2014, 10:47 PM
tfthach13's Avatar
'09 C63
Michelin Pilot Super Sports are your best bet to address traction issues. Tread wear is medium, but they're pretty good for a summer tire.
I'm curious as to what you mean you bought a rear wing for the highway to help with tires breaking loose? Even the C63BS' wing doesn't attribute much to downforce.
Old 01-20-2014, 11:59 PM
DialDforDan's Avatar
GTS
Mine is tuned and kinda turns tyres through 2nd gear but nothing thereafter... maybe you've got **** tyres?
Old 01-21-2014, 12:17 AM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Lol! Welcome to the C63 world!
No matter what tires you choose you will always get them spinning
That is one of the fun factor of this car.
We have a very poor factory offset in the rear therefore we cannot put very wide tires unless you do a widebody conversion.
How long have you been driving it? Learning the car and how to feel/feather the pedal can help too.
Old 01-21-2014, 02:00 AM
C3Duece's Avatar
2002 C32AMG
this is the truth. If you're really serious about traction you'll at least get the rear wheels widened...if that's even a word.
Old 01-21-2014, 02:35 AM
CarHopper's Avatar
E63S | X5
I've got 10.5's in the rear on 275 michelin PSS. Seems to work quite well, but really no matter the tire if you're mashing it off the line as much as it seems you'll burn through any tire quickly.
Old 01-21-2014, 07:51 AM
callmiro's Avatar
2016 C63 S
Whatever brand you go with, make sure you go with a wider diameter to increase the contact patch....265's and 275's are common in here. I ran Bridgestone RE-11's....
Old 01-21-2014, 11:54 AM
alexmtl's Avatar
2013 C63 coupe P31
Subscribed
I used to have PSS and they're outstanding in twisty roads, but not so much in straight line unless they are warmed up first.
Old 01-21-2014, 12:14 PM
Kriston's Avatar
C63 AMG
As others have mentioned look for wider tires. If you are losing traction in straight lines it will be hard to correct with just tires.
If you feel you are slipping during corners, perhaps a limited slip diff will help out (if you do not already have one equipped)
I would say a combo of wider tires + LSD will help.
Old 01-21-2014, 03:12 PM
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
Typo alert - I'm thinking Callmiro meant wider tire, not wider diameter.
Old 01-21-2014, 03:26 PM
MB 2009 C63 AMG
Spinning Tires
Thank you all for your Input.
Please bear in mind I was a BMW Person until August. This was my first post and some of the abbreviations are not familiar to me.
1. What is PSS
2. On stock rims how wide a tire can I put on?
3. My BMW 335i had the same width tire on the rear, and alot less HP and TQ even with modifications which were many - It put out 385 at the tires on the Dyno
Bear with me while I get used to the new abbreviations.
Matt
56 yrs old and disabled with 14 pieces of titanium in my back.
Plus one overdose given in the Hospital ICU. Memory has been bad since
Old 01-21-2014, 03:57 PM
CarHopper's Avatar
E63S | X5
1. What is PSS
Matt
1. PSS = michelin Pilot SuperSports. Surely you've heard of that tire.
2. On OEM's you can get a 265 on the rears, but I wouldn't go any wider on stock wheels.
3. I had a 135i with jb4+downpipes. Mean little son of a gun. Fun cars are those 35i's.
Old 01-21-2014, 03:59 PM
b7bydesign's Avatar
'11 BMW E90 M3
1. What is PSS
Matt
Matt,
1. I believe PSS stands for Michelin Pilot Super Sport tires as others have mentioned in this thread (http://www.tirerack.com/tires/tires....ot+Super+Sport)
2. Depending on the tire, I believe others are running 265 or 275's in the rear. I'm sure others will chime in regarding this though as I'm new myself.
Edit - PurpleHeart beat me to it
Old 01-22-2014, 12:38 AM
roadtalontsi's Avatar
10 C six trizzle
the pss are a good tire but definately sacrifice performance for tire life, wet performance and noise levels. If you dont care about life, wet performance or noise. get the toyo r888. You'll realize why people always say the best possible car modification is tires, because its the only thing connecting the car to the road.
Old 01-22-2014, 10:10 AM
Jason Anthony's Avatar
2013 C63 AMG Coupe
Running 285/25/20 rears
Old 01-22-2014, 10:17 AM
Quadcammer's Avatar
96 and 08 911 turbos
if you are in an area where the temps are cold (below 40 degrees), of course the car will spin the tires. summer tires are rocks in this temp.
when the weather is warmer, a decent 265 street tire should have no problem with the power your vehicle develops, especially in the higher gears.
Old 01-22-2014, 12:54 PM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
i ran 295's toyo r888s on rear of my moddified E55 (which is a trq monster) and it handled it pretty good (just dont drive fast on the highway in the rain).. the PSS and any other normal street tire would just spin like no tomorrow and hook like crap
now that i have a C63 the wheel spin isnt near as bad on the PSS as it was when running them on the e55, but even in stock form i can spin them pretty easily... getting tuned and longtubes this week so after that will probably need to get a set of toyo r888s again in 275
weistec S2 is in the future as well so i will be back to e55 power/trq levels and traction problems again... que sera sera
Old 01-22-2014, 01:39 PM
Former Vendor of MBWorld
Extreme Dimensions's Avatar
Too Many To List
The supersports are amazing tires, as are the R888s. Toyo Proxes (i believe t1?) are pretty good as well. Increasing wheel and tire width will give you the most traction.
Old 01-22-2014, 01:44 PM
Merc63's Avatar
C63 AMG
I really like the RE11s, they grab very good, tread life is good if you remove some rear toe and wet traction is unreal.
Old 01-22-2014, 05:23 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
I have 265 in the rears. Conti Extrm DWS. It hooks when its new and all temps. Now its down to wear bars. 1st gear its useless. 2nd its not bad.
Quick Reply: Cannot Keep tires from spinning at any speed
