C63 AMG (W204) 2008 - 2015
Something is wrong...but what?
Old Jan 27, 2014 | 08:24 PM
vtune's Avatar
E92 335i / C63 AMG / GSX-R 600
fuel consumption
Hi everyone,
what kind of fuel economy are you getting in the winter
Old Jan 27, 2014 | 08:30 PM
Nanook's Avatar
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
I would start by checking the air filter and tire pressure..
Old Jan 27, 2014 | 08:41 PM
vtune's Avatar
Old Jan 27, 2014 | 09:53 PM
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
Might be a stupid question but did you check for a fuel tank and fuel line for a leak? That is terrible mileage even if you were beating the snot out of it you should get better mpg than that. My fuel mileage goes down when the temp drops (air density) but nothing like what you ate explaining.
Old Jan 27, 2014 | 09:56 PM
charliekay's Avatar
C63 AMG
It is hard to say what the problem could be but a couple of questions that I think that may help are:
1. Is the check engine light on? Maybe get the car scanned for errors.
2. Do you regularly use the aircon?
3. Do you sit in traffic alot?
If the answer to all these is no then there might be a problem with an 02 sensor, spark plugs etc..
I get 300-350km, sometimes more out of a tank but I don't do alot of city driving. I have done trips where I set cruise control for 150+ kms and get 10.5-11L/100km. This morning I took the C for a drive and got stuck in traffic, and the car averaged just over 20L / 100km because I was in traffic.
Hope this helps a little.
Old Jan 27, 2014 | 10:03 PM
Merc63's Avatar
C63 AMG
Idling to warm car will kill mileage and driving in the cold short trips as well.
I get about 300 in the city or 200 when I drive in manual mode with lots of downshifts.
Old Jan 27, 2014 | 11:19 PM
Nanook's Avatar
And your tune (if you have one) may need some tweaking
Old Jan 27, 2014 | 11:27 PM
vtune's Avatar
Thanks for all the help.
There is no tune - it is all stock.
Old Jan 27, 2014 | 11:29 PM
Nanook's Avatar
One last suggestion...plugged cats
Old Jan 27, 2014 | 11:33 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
I did 460ish kms on my last tank (288mls). I drive the car daily (26mls) mainly highway in C mode unless i decide to do some spirited driving usually on friday ! lol !
But yeah i noticed idling, city traffic kill the mpg quickly. Having a vacuum leak will reduce it as well.
Old Jan 27, 2014 | 11:35 PM
abcut973's Avatar
I guess i should check the gas line for leaks, but again eurocharged found nothing wrong with the car during their inspection.
There is no tune - it is all stock. No check engine light either.
My read out says 27L / 100 KM, which is about 9 MPG. In city driving and no revving / speeding this is much worst than I had expected.
Reset your on board computer and see if your average reads the same. As mentioned previously city driving kills the mpg badly. What part of the world are you?
Old Jan 27, 2014 | 11:45 PM
vtune's Avatar
I am in Toronto Canada.. It's been around -20C this week.
I did reset at full tank, end of tank was 27L, I also check the after start read out and it is slightly less, 22-23L/100KM
Most of my drive has been in the city with a bit of highway, not much traffic. I will try to see how it does on a highway stretch.
Old Jan 28, 2014 | 12:47 AM
mercedes4ever's Avatar
2004.7 C180 Kompressor, BMW X5, Chevrolet Camaro LT, Mercedes S, Cesna 152.
You would get better running 98 octane. When was the last time the spark plugs were changed?
Old Jan 28, 2014 | 01:06 AM
CPD SLK's Avatar
2009 C63 AMG
Can you take it back to who you bought if from? Where'd the car come from?
Old Jan 28, 2014 | 01:11 AM
aussie e55's Avatar
2009 C 63
i use 17 litres of shell ultra 98 oct. per 100 Kilm. suburan driving with air con. on
Old Jan 28, 2014 | 08:08 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Try Shell or Esso 91. The Petro 94 is loaded with ethanol.
Old Jan 28, 2014 | 08:16 AM
Quadcammer's Avatar
96 and 08 911 turbos
also keep in mind that oxygenated fuel delivers worse fuel economy, but that shouldn't have this kind of impact.
Old Jan 28, 2014 | 08:28 AM
aussie e55's Avatar
2009 C 63
i understand usa 94 octane is the same as aussie 98 octane is this correct ?.
Old Jan 28, 2014 | 08:37 AM
crazy1eye's Avatar
2016 C63S, 2012 ML350
Yes, I believe 98RON = 93M+R/2
Old Jan 28, 2014 | 09:51 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
That's news to me, I always thought Ultra 94 has very little % of ethanol.
Old Jan 28, 2014 | 09:57 AM
crazy1eye's Avatar
It can have up to 10% ethanol according to Petro-Canada
Old Jan 28, 2014 | 10:00 AM
Roswell's Avatar
Is this bad? I've been using Ultra 94 religiously since the day I bought my car cuz this is the highest octane we can get in Canada. LOL
Old Jan 28, 2014 | 11:35 AM
Mort's Avatar
With 94 octane you potentially get a little more performance and with the alcohol lose a little gas mileage. Fair trade off? Depends on how well the 94 burns in our cars and if it reduces knock vs 91 Shell then you will get a slight performance improvement. Not sure what performance you will get in reality.
Our cars can use fuel with up to 10% ethanol so you should be fine using Ultra 94 with no harm to your engine or fuel delivery system.
561design's Avatar
2014 VW Touareg, 2012 C63
This would be my first suspect. Also, your tire pressure can affect your mileage as well. A combination of the current temps, bad plugs and low PSI could contribute to you're low numbers.
Old Jan 28, 2014 | 04:37 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Yeah it does. Refineries here suck. They need it just to get the octane rating.
http://retail.petro-canada.ca/en/ind...ee%20gasoline?
Originally Posted by Petro Canada
Does Ultra 94 contain ethanol? Does Petro-Canada still offer an ethanol-free gasoline?
Ultra 94 contains ethanol. Due to the fact that various fuel grades are blended at the point of sale, most grades of Petro-Canada fuel may now contain up to 10% ethanol. This represents a change from the previous state, where premium fuel was ethanol-free at Petro-Canada.
Checkout this site
http://pure-gas.org/index.jsp?stateprov=ON
