C63 AMG (W204) 2008 - 2015
Quick-Attach Front Plate?
Old Feb 21, 2014 | 02:58 PM
goatfarmer1970's Avatar
C63 Coupe 507, CLK55 Convertible, X1 35i, 70 GTO convertible, motorcycles
Anyone have a way to quickly attach a front plate when parking (without drilling holes)...like a magnet or some other form of quick-connect? I have gotten a few tickets lately while parking but am not quite ready to install a front plate all the time. And unfortunately, just placing it on the dash does not prevent a ticket. Thanks.
Old Feb 21, 2014 | 03:01 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
Get a Gominigo plate holder. It attaches to the front tow hook.
http://www.gominigo.com/
Old Feb 21, 2014 | 03:40 PM
Guilty's Avatar
'16 C63-S
million bucks idea... i always wondered why something like this doesn't exist. I bought the tow hook thing but it looked disgusting (it still looks good on your car jeff, i saw it at the bodyshop). But on the lexus it looked nasty lol
Old Feb 25, 2014 | 11:52 AM
Lots of options if you have a Mustang, and some for our cars if you are willing to give up ground clearance at the front valance (which I am not). Anyway, I just bent some paper clips and hooked the plate through the mesh of the lower grill. Based on how easy that was and that it worked well enough, I plan to fashion something similar in concept but better executed. Then I will just hook it on when I park in metered street spots.
Old Feb 25, 2014 | 11:59 AM
I am Jeff's Avatar
I got tired of NYPD pulling me over and harrassing me because I was running without a front plate. That's my next best option. Thanks Alex!
Old Feb 25, 2014 | 11:55 PM
NellyRod's Avatar
2012 C63 AMG BS, 2010 DUCATI 1198S
Can anyone confirm the towhook mm measurments for a 2012 C63 coupe? I'd like to order one of the kits but the site has 100mm and 130mm options.
Old Feb 26, 2014 | 12:04 AM
149max's Avatar
+1 would like to know also.
How about if you have park sensors? Will these block the sensor? Or can you fiddle with it to make it work?
Old Feb 26, 2014 | 12:52 AM
roadtalontsi's Avatar
10 C six trizzle
ya it's going to make the park sensors angry.
Old Feb 26, 2014 | 02:30 AM
Goni C63's Avatar
C63/X5/ML/YUGO
Since new I never had front plate & present but I did get 3 parking tickets since new what do you guys think about motorized plate holder that flips under the bumper and when you press botton comes back up saw it on my friends M5 E60!
Old Feb 26, 2014 | 07:19 AM
w204nyc's Avatar
2017 C63S coupe '09 C63, '15 Durango RT, '14 Jeep SRT8
Goni i had that. Its nice but it shows if you look at the front of the car. You cant push it too far under the bumper because then it wont flip out. Lost mine over a bump. When its hidden under you bumper, it sits very low to the ground. If you are gonna do it, have a professional place install it through the lower mesh.
Old Feb 26, 2014 | 11:13 PM
A C's Avatar
A C
2016 E350
Plate
I had the same issue. After a ticked while parked I decided to try and mount the plate in the mesh.
Using a series of screws, washers and bolts I managed to create a mount inside the mesh off to the side. Works great and doesn't show. Make sure the screws are about 4" long. Using a big washer and a bolt mount the screws facing out. Set the plate in to level the screws, remove and then tighten the base bolts down tight. After getting those set, mount the plate and the second set of bolts.
Old Feb 26, 2014 | 11:16 PM
LAMB09's Avatar
2011 C63 AMG
I have the RHO plate, really only use it when I get a ticket. Throw it on go get the ticket signed off and take it back off. Easy to install good quality, doesn't look bad with it on all the time but I like my front end clean, lol.
http://www.rhoplate.com/
Old Feb 27, 2014 | 09:10 AM
I am Jeff's Avatar
NYC tickets don't work that way. If you get a ticket, the burden of proof is on you to prove that you had it on. The benefit of the doubt is given to the cop that wrote your ticket. Believe me, I've tried and lost that argument. It's not a fix it ticket here.
