C63 AMG (W204) 2008 - 2015
What do you guys think/know about these oils?
Old May 19, 2014 | 01:48 PM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
Getting tired of reading how crappy the Mobil 1 oil is for our cars. And yes, I drive my car in all ways, track and grandma. So what do you think about these oils being better for the M156, better than the Mobil 1?
Liqui Moly
Redline
Total
Old May 19, 2014 | 02:15 PM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
Total and Liqui are on the list, Redline is not, I would skip that.
Where would you even buy them is the question.
Old May 19, 2014 | 02:27 PM
jcfay's Avatar
2018 AMG E63s
As a new C63 owner who finally decided to buy some of the Mobil 1 ESP after much reading and feedback, I decided on using either olive or canola moving forward and seeing what the heck happens... At least it should smell kinda good...
ZephyrAMG's Avatar
Well I read great things about luquid moly (German made oil for high performance race cars). Not so sure about Total but redline is also used in high performance race cars.
Old May 19, 2014 | 03:37 PM
Ingenieur's Avatar
C63 AMG
it's all pretty much the same if on the list
do regular changes
let the oil get hot before 'using' it hard
Old May 19, 2014 | 03:43 PM
bhamg's Avatar
C63 AMG
Excellent oil, VOA is virtually identical to the Motul 8100 X-cess 5W40 that I use.
Old May 19, 2014 | 04:13 PM
ZephyrAMG's Avatar
Yeah. I think I am going to take my car to and INDY and have them put in Liquid Moly and take out the mobile 1. Dealership here refuses to cooperate if it is not what Benz says I have to put in the engine.
Old May 19, 2014 | 04:15 PM
ZephyrAMG's Avatar
do regular changes
I guess there is my concern. Are they all really the same? Aren't we looking for low build up and excellent resilience and lube with hotter engines?
Seems like Mobil 1 is too "thin" and does not hold up after a hot track day...
Old May 19, 2014 | 04:41 PM
Fung63's Avatar
my wife bananas! :D
I use motul for my car.... it is great!
and its on the approved list
Old May 19, 2014 | 04:49 PM
ZephyrAMG's Avatar
Thanks Fung...good to know. I'll look into it.
Old May 19, 2014 | 05:22 PM
dubzAMG's Avatar
2010 C63 AMG FBO, 2014 E63 AMG S
I use motul xcess 8100 5w40 as well.
Old May 19, 2014 | 05:46 PM
Ingenieur's Avatar
C63 AMG
you'ld be hard pressed to find a wear difference between these oils after a couple of 100k miles of use
getting oil hot and burning off contaminants and water is good
that is why short trips are a harder service duty on oils
much of it is placebo and preference
not saying changing is bad, but that there is nothing wrong with Mobil 1 and 'better' is subjective in this case, not objective
I would never use ANY oil not on the 229.5 list in our case (0W40 or 5W40 wt.)
do a cost analysis
cheaper to run Mobil 1 at 6k intervals vs 'other oil' at 10k?
Mobil 1 at 6k is going to be better than the others at 10k miles
Mobil 1 can be had at <$25 for 5 qts http://www.walmart.com/ip/Mobil-1-0W...Quart/23636902
if the other oil is $10/qt you can do 5k changes with the Mobil 1 vs. 10k with the other
which will be better?
Old May 19, 2014 | 07:02 PM
bhamg's Avatar
C63 AMG
I bought 20 liters of Motul in 5 liter jugs - cost shipped to my door was $6.35 per liter. Cannot beat that...
Old May 19, 2014 | 07:22 PM
tfthach13's Avatar
'09 C63
I've been using Redline pretty much since I got my C63 2 years ago. Engine runs as smooth as the day I got her...maybe even better since she ran Mobil1 for about 10k miles before I bought her.
Anyways, consistency is the key. Which means regular oil change intervals at approximately 6-8k miles, with the same oils. Just make sure the viscosity is correct.
Old May 19, 2014 | 07:54 PM
CPD SLK's Avatar
2009 C63 AMG
Redline or AMSOIL. I prefer AMSOIL, but either is great. Royal Purple is crap. Mobil 1 sucks in my opinion (oil pressure drops with Mobil 1 in my Trans Am but does not with AMSOIL).
Old May 19, 2014 | 08:51 PM
ruey220's Avatar
ml55, Ml63, Porsche, C63S ED1
I'm surprise you think negative about redline, used to use them back in my more hard core drag and racing days, but surprised he didn't mention amsoil.
frankly, if you change the oil sooner than later you will hardly notice the difference. filter usually goes sooner than oil.
Old May 19, 2014 | 08:52 PM
ruey220's Avatar
gI stopped buying into the hype of all the different oils since I got scammed by slick 50 and duralube.
Old May 19, 2014 | 10:21 PM
andrew c230k's Avatar
W204 C63 R171
I'm using Liqui-moly in my C63, seems to have slightly less valve noise then 0W40 Mobil One, and I haven't really noticed my sticky lifter either since switching. I'm running 5W40 Liqui-moly I bought a case of 5 L jugs for a great price.
Old May 19, 2014 | 10:26 PM
ks4life's Avatar
w204
what about petronas? anyone?
Old May 20, 2014 | 12:39 AM
Merc63's Avatar
C63 AMG
All this talk about oil.
Never once in my life have I heard someone have to tear down an engine because the oil wasn't good enough.
Keep it clean and change it often is your best bet.
Old May 20, 2014 | 08:24 AM
Ingenieur's Avatar
C63 AMG
bingo
and I might add use an oil on the list of the proper wt.
good to go
all this ballyhoo reminds me of chicks and shampoo brand talk
Old May 20, 2014 | 08:40 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Curious how oil makes it on "the list". I don't see Shell Rotella T6 listed and it's much better most of the oils on "the list".
Old May 20, 2014 | 01:36 PM
ZephyrAMG's Avatar
I think "changing it often" is relative. MB says every 10k miles. We all never go that long. Is 2k miles "often"? I mean what's often? It depends how you drive it. After a track day is a good time to change. But I want to know in the long term, if you had an oil sitting in your engine, whatever the change interval, what would it be.
I also agree with less of a lifter noise by using a better grade oil...
Old May 20, 2014 | 03:38 PM
Ingenieur's Avatar
C63 AMG
BMW calculates change interval this way when resetting the oil service:
miles to next oil change = 666 x avg. mpg from previous reset
if you average 20 mpg (driving easy in an e46 M3) interval = 13,300 miles
if driven hard and say 14 mpg ~ 9300 miles til next change
I'd say 7-8k changes for our car is fine as long as a good mix of highway/town
if mostly highway the 10k is fine
if mostly city/town I'd do 5-6k
but to each there own
Old May 20, 2014 | 05:06 PM
jvanbrecht's Avatar
Read my comment carefully. I said nothing bad about Redline, other than it is not on MB's approved list. I would skip it. Yes I know there are plenty of good quality oils not on the list, but if push came to shove for a very expensive repair under warranty, you can bet MB will look for a way to weasel out of it. Blown engine, and they determine the oil is not on the list, you have a long uphill battle.
