Weistec Engineering Oil/Air Separator Group Buy 2014
Go test it out.
So I'll get a replacement bolt (I'm wondering if I can't use the OEM PCV bolt to connect one of the Weistec housings?), I'll do a reinstall. As much as I pushed and pressed, however, I couldn't get those fittings to seat totally flush in the manifold. The other issue is that my kit (and I imagine everyone's) didn't come with the billet adapters shown in the instructions that would allow one to apply a wrench to both sides of the fitting when then attaching the hoses. I guess they changed the setup which is now more simple with the billet being threaded itself, but like was noted there now isn't any wrenchable mating surface on one side of the fitting. But it looks like all is working well.
Also check at the hardware store. They may have a bolt in their metric drawers that will work. Maybe even SS vs the plated bolts in the kit. The bolts are M6 x 1 X 16mm in Allen head design as a hex head design may not allow enough clearance to tighten with a ratchet as a wrench might be awkward to use.
Last edited by Mort; Jul 7, 2014 at 10:16 AM. Reason: Replacement bolt at hardware store?
